Is the function of the capacitive door handles with Keyless-GO limited? Is opening the doors not possible?
A proposed solution:
The capacitive door handles respond to touch. The necessary "conductivity" may not be fully present with dry skin, which can certainly occur in winter.
It's similar to using a smartphone with light gloves on.
Solution: Apply moisturizer/hand cream to your hands, or if that's not available, moisten your hand in another way.
Background: The capacitive sensors generate an electric field. The touch of the hand alters this field, which then leads to the door opening when the authorized vehicle key is nearby. Dry skin is simply less conductive, which results in the electronic field not being sufficiently altered.
