Common Technical Product Information (TPI)
Melfinos
Lebt hier ★
European-Union
Hier soll eine Sammlung der bekannten TPI entstehen.
Daher die Bitte an euch alle um Unterstützung zur Weitergabe eurer Infos in diesem Thread.
(y) ;)
At the ROC, there are brake pads, some batches of which "moo". The term is actually known as such at VW.
Before making a complaint, it is best to record a video showing the number plate clearly.
The pads will be replaced.
Since it did actually happen that "mooing" pads were installed a second time during the replacement, the corresponding TPI has been revised.
The currently valid TPI has the number: 2049996/10. The part number of the correct pads must end with a "J".
Maybe this helps you.
TPI Code 2075376/2
Inhalt: ???
TPI Code 2075376/2 Inhalt ???
TPI 2076933/2
Maßnahme:
TPI 2070059/3
Maßnahme:
I have a 1.5 eHybrid (272HP)
I received the following information about my VIN in ERWIN.
5x high voltage / charging technology
1x CarPlay
Edit by @stefanerWin manuals removed due to copyright infringement. Please take note in the future. Thank you :)
TIS, to fill the silicate in the coolant reservoir
do I understand correctly that this refers to the coolant itself, which can potentially lead to flocculation in the cooling circuit, manifesting as silicate flakes /-clumps /-sludge in the expansion tank?
The problem has been known at VW for years, and if there is now a TPI regarding this, all the better.
The "old" coolant G13 (written on the expansion tank) is organic, more environmentally friendly, and cheaper to produce. Unfortunately, it has the property of dissolving the coating of the coolant hoses, leading to deposits in the expansion tank.
The "new" coolant G12 EVO (also written on the expansion tank) is mineral-based and does not dissolve the coating, so no flocculation occurs.
In 2020, a ROCer writes that "everything will be replaced under warranty (heat exchanger, expansion tank, coolant)." Which of the two coolants will be refilled afterwards is decided by VW. Hence the note "written on the expansion tank."
I suspect that "silicate" is likely sodium silicate, which is mineral-based and can also be used as antifreeze (or as a binder in paints and plasters or as a weed inhibitor in joint sand). It is highly caustic when undiluted, with a pH around 11...
I'm looking forward to my inspection; let's see what all gets fiddled with and what errors will be fixed by then...
@Gand-Alf
Thank you for the information. I was not aware of the flocculation issues related to the G13 coolant until now.
Perhaps a small addition. In our ROC, G13 is also filled, at least according to the label on the expansion tank. It has not had any flocculation so far after a total of six inspections.
Therefore, it is reasonable to assume that the G13 may only affect certain coolant hoses, a specific batch, certain model years, or engine configurations. The aforementioned colleague had a 2.0 TSI at that time. Perhaps different hoses are installed there. By the way, G13 was refilled for him again :oops:
Since I had enough other things to do, I didn't ask.
But I think that this silicate container was simply refilled in the expansion tank or maybe it was first installed 🙈. Or removed because there were problems 🤷‍♂️.
