Buy a Cupra Formentor from 2025 or get the pre-model used??
McMillionaer
Hello everyone!
I'm new here and would like to change my current vehicle to a Cupra, as I really like the shape. However, I have the question, since finances are a bit tight, is it better to buy the one from 2025 for up to €30,000 or to settle for the predecessor version with the larger grille - which is cheaper? I'm interested in your experiences regarding faults/problems - because I'm not really a fan of workshops. Oh, and it should be a hybrid/petrol. Thank you very much for your tips.
So, it really depends on what is "more important" to you. The FL has a few small advantages, like more electric range, a better infotainment system, and if you value Sennheiser.
On the other hand, of course, there's the price! Personally, I would recommend that if you decide on a vFL, you should go for one of the ones that were built last, as the "teething problems" are usually resolved by then.
We also had the "teething problems" with the FL that were built first, not everyone of us experienced them, but if you order a new one now, you probably won't have to deal with most of those issues anymore.
If you have any further questions, feel free to write here and I can gladly provide you with more information.
Best regards
Hi,
it's basically a matter of taste; I personally prefer the old Formentor a bit more in terms of appearance, as it looks bulkier with the large grille.
As for the technology, it has @Ice-Mark I've actually written everything down. I drive both variants (FL/VFL) of the Leon and find the difference not significant enough that I would spend 10K more for it. If FL, then none built in 2024, as there was/is the biggest problem, ideally a VFL built from 2023 onwards. However, there are Monday models everywhere, but for the mentioned time periods, the likelihood is greatest that no major concerns will arise.
