Welcome! You have been invited by kuchen25 to join our community. Please click here to register.
justaddgas76
VZ 333 / first impressions:
First of all — I am completely satisfied.
I have driven 840 km, 95% of it quite defensively. 50:50 country roads and highways.
I averaged 8.2 liters of Super 98.
Motor: Power in all situations, even in NORMAL mode. Accelerates smoothly up to the limiter. At the limiter, the speedometer shows 267 km/h.
Sound: In comfort mode, it’s not really loud, sometimes it just slightly rumbles in overrun.
In sport mode, it’s better with slight support from the sound modulator.
Cupra is a bit too much for my taste with the sound modulator (matter of taste).
I will customize something in Individual.
Bremse: I was surprised that the VZ facelift comes with a large brake system with perforated brake discs. It wouldn’t have been like that with the pre-facelift.
Diameter should be 310. I have gently broken them in for now, but they bite well.
I don’t even know if you would still need to order Brembo — they have 320, I believe.
Winterräder: I got 225/40 R18 from the Cupra dealer — they just fit over the brake system.
Assistenten: We now have a button on the steering wheel. Turning off the speed warning and lane assist can be done with 3 clicks on the steering wheel. You don’t have to go into the menu.
Infotainment: No comparison to the pre-facelift.
All errors have been eliminated. Nothing to complain about.
Inductive charging pad: works perfectly with the iPhone, unlike the pre-facelift. Not once has it not worked. It doesn’t have too much power.
With Maps and music, it keeps the battery.
Sitze: Dinamica looks very good to my taste and feels great. I actually ordered Sharp textile with the pre-facelift and am very happy with the Dinamica.
The blue accents are very subtle and only show through the holes in the upper layer. Not visible in the shade at all. In direct sunlight, you can see it, but for my taste, it’s still subtle enough.
If I forgot anything, feel free to ask. I will take photos this week and post them in the showroom.
Zum Sound: Also ist der Soundgenerator bei jedem Neustart an?
Das ist was mich (noch) am Octavia RS ankotzt: 4 Zylinder der auf 8 Zylinder macht…
Zu den Winterrädern: Welche ET?
Start ohne Soundgenerator im Normal Modus. Aber ja, im Cupra Modus ist das auch so übertrieben.
ET kann ich dir gar nicht sagen … 🫣
@justaddgas76 vielen Dank für deine ersten Eindrücke, gerne später noch was zur App und die Funktionen sagen. Freue mich schon, dass die Ladeschale doch nicht so schlecht ist, wie erst angenommen war. Wie zufrieden bist du mit Kessy? Wo genau muss man den Fuß hinhalten für die elektrische Heckklappe?
Vielen Dank schon einmal
VZ 333 / erste Eindrücke:
Assistenten
: Haben jetzt einen Knopf am Lenkrad. Das Abschalten von Geschwindigkeitswarner und Lane Assist mit 3 Klicks am Lenkrad machbar. Man muss nicht ins Menü.
Vielen Dank für deinen ausführlichen Bericht 👍🏻 und weiterhin viel Spaß mit deinem neuen Cupra.
Zum Thema Assistenten abschalten:
Geht, u.a. wie du schon geschrieben hast, auch recht schnell und einfach über das Infotainment System. Habe dazu ein kurzes Video gemacht, aber die Datei mit 20mb scheint zu groß zu sein. Gibt sicherlich irgendwo Seiten im Netz wo man sowas teilen kann, aber ich weiß nicht, ob solche externen Links hier erlaubt sind.
Danke @Ice-Mark … Die App ist kurz gesagt Mist, wie finde ich. Fand ich die alte Cupra Connect App viel besser.
Kessy ist super und funktioniert einwandfrei. Besonders das neue automatische Öffnen und Schließen bei Annährung ist genial. Beim automatischen Verriegeln mit akustischer Bestätigung oder akustischer Warnung, wenn nicht zu verriegeln geht. Auch die Welcome Ceremony der LED Scheinwerfer bei Annährung hat was 👌🏻
Hatte den Fuss links von der Mitte unter die Stossstange gehalten — ging super.
Aber das ging beim vFL auch schon super.
So ersten 400km sind gemacht, da ich noch ein bisschen am Einfahren bin kann kann ich zur vollen Leistung nicht viel sagen aber im
normal Betrieb ist er super und es mangelt auch nicht an Leistung. Auch das Entertainment funktioniert super und schnell. Einzige Mangel denn ich bis jetzt gefunden habe ist die Ladeschale. Bei Abholung hat sie super funktioniert jetzt gar nicht mehr, wenn ich das Handy (Iphone 15 pro) reinlege, wird das Symbol angezeigt jedoch rot. Werde morgen mal den Händler kontaktieren.
Ansonsten bin ich jedoch rundum zufrieden.
Da der Wartesaal-Thread inzwischen für alles mögliche genutzt wird, unter anderem auch für Unterhaltungen erster Erfahrungsberichte, wäre es cool wenn man diese in einen anderen Thread (z.B. diesen hier) packen könnte um bessere Übersicht zu haben. Also gerne wer sein neues Spielzeug bekommen hat hier posten (oder im Showroom), anstatt alles in den Wartesaal zu packen. Threadname kann gerne vom Admin umbenannt werden.
I don't even know if you would still need to order Brembo — they have 320, I believe.
Looks more like the dimensions of the "old" Brembo to me. It has 370mm in the front and 310mm in the back. For the VZ 333, you can only order Akebono now, and that one is even larger than the Brembo (which is only orderable for the VZ eHybrid as far as I know). The stock brake on the VZ eHybrid has 340mm in the front and 310mm in the back, like my current GTI. And with the brake system from the Golf 7 GTI Performance, I have significantly more clearance with 18".
But you can measure it, I would actually be interested.
Ein weiterer Fehler ist mir aufgefallen. Die Ambientebeleuchtung flackert gerne mal und er hat sporadisch Probleme mit den Rückleuchten. Er möchte dann, dass man diese kontrolliert. Hoffe, dass das mit den nächsten Updates behoben wird.
Das mit den Rückleuchten hatte ich auch am Anfang. In den ersten 3 Wochen nach Auslieferung, jeweils 1x pro Woche. Die Rücklichter leuchteten aber trotz Meldung. Ist aber seitdem nicht mehr aufgetreten.
I’d like to add my two cents here. I've been driving the eTSI in the facelifted Leon ST since early August, about 2500 km so far.
So far, I have had zero problems with the lighting, inside or outside.
Kessy doesn’t seem entirely reliable, especially when closing. I need to see if I can find the setting for a warning when it doesn’t close... The car was left unlocked for 6 hours today without any signal in the parking lot... not great! Also, closing via remote is sometimes hardly possible unless you’re within 2m of the vehicle.
Charging pad: rubbish, in my opinion.
Yes, it "charges" the smartphone battery with Android Auto. I don’t actively use Google Maps, but it seems to run in the background? Well, the inductive charging was supposed to be improved, but it seems like too much was advertised...
The front USB-C ports are junk as well. The same cable on the 12V adapter or at the connections for the back seat: suddenly it’s fast charging?!
Cupra, are you serious??
So sorry, enough complaining ^^
(Except for the points as an early buyer, but I have a separate topic for that... I’ll be visiting the dealer soon regarding some issues and I’m curious how they will assess certain flaws.)
I come from the 125PS Seat Leon FR with a 6-speed Manual* transmission (2015) and MIBv1.
Now I have the 150PS eTSI, 7-speed DSG, DCC, MIBv4...
Of course, I’m in heaven :)
Even after 2.5M and the points mentioned above, every step towards the car makes me happy, every drive is a joy, even traffic jams are much more relaxed. The infotainment makes my Seat feel very "old," now it’s top modern, fast, functional - simply excellent!
Im Infotainment Menü:
Fahrzeug - schließen - Dort findest du den Schalter, dass er warnen soll, wenn nicht abgeschlossen wird. Problem wird dann aber vermutlich weiterhin bestehen. Bei mir warnt er eben nicht, wenn er sich nicht abschließen sollte. NUR wenn eine Tür oder Kofferraum noch offen ist, dann kommen die beiden Pieptöne.
Ich habe mir angewöhnt, wenn ich auswärts irgendwo parke, dann schaue ich ein paar Sekunden später in die App rein, ob das Fahrzeug verriegelt ist.
Induktion habe ich deaktiviert. Handy soll geladen werden und nicht den Akkustand halten. 😃
Aber auch ich bin sehr zufrieden mit dem Cupra. Vom Interieur und von Außen finde ich ihn jeden Tag weiterhin sehr sexy. 😉
I'll test it tomorrow, thanks!
PS: The options are already all active. I have now manually turned them all off and on again.
When removing the car, I heard the beep and the locking after 4-5m.
The 1 or 2 tones occurred so rarely in the past that I simply didn't know what they meant..
I'll mention it during the workshop appointment.
Ambientebeleuchtung ist anscheinend bei einigen das Problem. Dazu gibts schon einen Thread - https://cupra.forum/threads/ambiente-beleuchtung-flackert.144/
Wär toll wenn du da irgendwann einen Lösungsvorschlag erhalten hast :)
Hello everyone,
Has anyone already been able to gather information or experience with the "standard sound system"?
Pre-facelift ordered without Dynaudio as it was not worth the extra cost, shortly afterwards received an email from the dealer: new facelift with better performance / equipment at the same price... unfortunately only without the Sennheiser sound system.
VFL, without a sound system is okay, as long as you don't like to listen loudly and value sound quality. If given the choice, I would always go with Sennheiser; if it's without, I could live with that. Beats was a bit better than the standard (both VFL), and Sennheiser is even better than Beats, so in my opinion, the extra cost for the normal system is worth it this time.
Edit: What are you driving now?
The standard speakers are completely OK. I didn’t expect that. The sound is fine.
But when you turn it up a bit, there’s quite a bit of rattling at the B-pillar on the driver’s side. The hands-free system, as well as the navigation prompts and speed camera alerts, sound somewhat better than with my Beats system from the 5F.
Still, I miss the bass and somehow the overall sound from my 5F with the Beats.
Cupra Leon 1.5eTSI, VFL, year of manufacture 2023. Leasing for 3 years.
Positive: Economical in fuel consumption both in the city and on the motorway.
That's all for the positives.
Negative: Engine constantly stalls despite SSA being deactivated, jerking when starting off, although only sporadically, but it feels like driving with a faulty clutch.
Interior workmanship, it creaks practically at every pillar, especially bad are the two door handles and front door trim. Also the storage compartment on the driver's side. Mirror dips when reverse gear is engaged but moves up instead of down.
Brake pedal cracks when braking.
Auto hold occasionally fails.
