Should the ventilation in the rear always be switched off?
kruemelgirl
Hello,
is it possible to completely switch off the rear ventilation?
I do this every time I drive, and it's quite annoying, especially since the rear climate control is always set to ECO, so it's always cold.
I couldn't find a solution for this in the climate menu on the Formentor FL.
Thanks.
@kruemelgirl disable it at the back – just like you’ve been doing...
And then don’t use the “Sync” button anymore, because that will also reactivate the ventilation in the rear.
Thanks.
But that means that later, if a passenger is in the back, the ventilation in the back will switch on again.
This morning, I checked and Sync was off.
Let's see how it is this afternoon
In this case, it shouldn’t switch on, no.
Sync is something different from ECO mode.
In ECO mode, the climate control is basically still active, but it detects that no one is sitting there and therefore doesn’t need to be used.
SYNC, on the other hand, takes over the temperature settings for the driver’s side and transfers them to all climate zones.
Try it like this:
Sync off, climate control completely off (in the infotainment system), and then set a separate temperature for the front.
@Angefixt
Even if I switch SYNC off, the rear ventilation is still on every time I restart the car.
Somehow, there’s no separate switch just for the rear ventilation.
Unfortunately, there’s no switch for something like that anymore :oops:.
You could simply close the "flaps" at the back like you used to.
In the Terra, you can adjust the climate settings for the rear from the main display, for example, setting it to 23° and then locking it. Is this not possible with the Formentor?
Yes, Leon ST (see also my signature ;)).
Das sieht im Leon genauso aus. Wenn du auf die zwei "Taster" schaust, mit denen man die Lamellen verstellen kann, dann dürfte da ein Sybol zu erkennen sein. Wenn man diese nach recht bzw, links verschiebt schließt und öffnet man die Lüftung (man sieht von außen auch ob die Lamellen in 2. Reihe offen oder zu sind. Müsste in dem Fall jeweils nach außen schließen. Das ist dan quasi die Funktion der "Rädchen" wie es sie mal gab.
