Lowering springs for CUPRA Leon Sportstourer VZ 4Drive – Comparison of H&R, Eibach, JE Design & Vogtland
Didi_Nbg
I recently got a CUPRA Leon Sportstourer VZ 4Drive with 228 kW and DCC suspension. Since I don't like the height, I would like to replace the springs with lowering springs. I have the Panoramadach, a Notrad with Subwoofer and retractable towbar installed. Therefore, I think the weight on the rear axle is a bit higher. What I don't want is a "saggy rear," meaning that my Leon is lower in the back than in the front.
Now I wanted to ask if you might have pictures of your Leon Sportstourer with lowering springs . Ideally, they should be regular lowering springs, so no coilover springs, as I don't think that's necessary for this vehicle and doesn't provide any advantage here.
Please include the following:
1. Manufacturer of the springs
2. Engine specification
3. Heavy optional equipment
4. Driving behavior difference compared to the original suspension
Thank you!
Hi, I believe there is already a topic on lowering, including pictures.
From the neighboring Forum, where the Formentor is dominant, there are reports on Eibach and H&R. The Eibach are even more comfortable than the H&R and closer to the stock suspension.
Yes, the other topic is actually about the e-HYBRID: Cupra Leon e-Hybrid ST Tieferlegung/Verbreiterung
It has different springs than the 4Drive. Therefore, you can't compare them directly. Eibach has linear springs, like the original - H&R has progressive springs, so the characteristic curve of the H&R doesn't match the DCC chassis optimally.
