Reminder "Mobile phone still in the vehicle"
Loco4
Stammuser ★★
I was used to being kindly reminded by voice when I got out of my previous car if my smartphone was still in the charging dock in the center console. Unfortunately, my Terramar only "reminds" me via text on the display, which of course you don't read once you're out of the car. However, I read in another Forum that there is supposedly also a voice reminder for Cupra. However, they are also not sure how it can be activated and it was discovered by chance when someone was accidentally logged in with the user profile "Guest." I couldn't find anything about it in the Manual*. Does anyone have any ideas?
Ah okay, danke @stefan 👍
Ich sehe, dort ist es ganz ähnlich und ebenfalls leider ohne Ergebnis gelaufen.
Greetings,
for me, it sporadically says that I still have my phone in the charging cradle.
Unfortunately, this is not reliable!
I can confirm the existing language prompt. Is it really due to the guest access?
Accordingly, the language prompt only appears when the system is in guest profile?
However, I did not find any activation/deactivation in either the guest or my own driver profile.
Is it a bug that the language prompt is not audible in the driver profile?
A test phase after switching from the personal driver profile to the guest profile unfortunately did not produce any language prompt today.
Thus, this function is likely also irregular/unreliable in the guest profile.
Can only an update fix the faulty function regarding the desired language prompt?
At the latest when you need the phone, you realise it’s still in the car; this usually only happens once or twice. Since the car already takes care of many things while driving, the driver can focus on not forgetting the phone when getting out 😉. You don’t really need something like that.
For me, it’s like this: I only have the phone in the charging cradle in the car at very irregular and quite long intervals. So I basically always forget it when I get out :LOL:
But of course, it’s not super important that my Terri kindly reminds me. Maybe there will be an update sometime.
So for me, sometimes the announcement comes up and sometimes only the notification in the infotainment system. However, it also happened to me the other day when I only had the mobile phone in my trouser pocket and was still in the car; I’m not going to forget it in the car then ;) :)
Grüßt euch, für mich etwas ganz neues. Wo findet man diese Einstellung um sich so etwas per Ansage mitteilen zu lassen ?
Glaub das es dafür keine Einstellung gibt, bei meinem kommt ab und an die Meldung, wenn ich die Tür öffne und mein Handy noch in der Schale liegt... aber die Ansage kommt da auch nicht immer, alle paar Male.
Im verbotenen Almanach hab ich dazu auch nur diese Stelle gefunden:
Könnte mir vorstellen, dass es damit einhergeht?
I found the rear seat warning. However, I have not experienced any improvement with the reminder message via voice output to the mobile device.
So my car tells me in a nice female voice that the phone should not be forgotten and whether all passengers have exited.
I haven't set anything, it has been doing this since the big update it received last week.
I will leave it as is, it's kind of cute. :)
