Hello.
I've noticed in the past with my Leon that the start-stop system is not active, even though it's switched on.
The engine does not turn off, and in the cockpit, I see the indicator that the shutdown is not active.
Admittedly, I often drive 10 km and 30 km routes, and every two weeks I take trips of around 200 km straight.
After a long journey, the shutdown works again for a while.
I had exactly the same problem with my Ford Focus MK4. After some time, the start-stop system stopped working, and it began to shut down consumers.
This manifested itself, for example, in the fact that the high beam could no longer be activated.
It was always like this during the winter months when temperatures approached freezing.
With the Focus, after extensive research, I fixed it by adjusting the BMS from 80% to 92% using Forscan.
Additionally, the problem with the Focus gradually occurred more frequently only after about 3 to 4 years.
I wondered, why should I buy a new battery? Just because the manufacturer has set the BMS in such a way that it supposedly has a protective effect for the battery?
My wife has been driving the Focus for 8 years now, and the battery continues to function flawlessly with the 92% setting.
Now my Leon is just over 3 months old, and I don't understand why such nonsense is already occurring here. Do the manufacturers want us to regularly buy a new battery? Or do we have to recharge them manually? What is your experience with electrical consumers during the winter months?
My second question is, why can't I search for abbreviations like BMS or similar in the Forum? This makes searching here extremely difficult.
The search could not be completed because the search terms were too short, too long, or too frequent.
Regards,
Gunnar
Oops! We encountered a problem.
Regards,
Gunnar
