Brake calipers with Cupra lettering
The caps should fit, but only if you have a VZ.
The weaker engines, including the 2.0 204PS, come from the factory with a different front brake; on new cars, the brake calipers there are not black but cast silver-grey. They only turn black after a few thousand kilometres.
Are mounted. Here you can see the
The Ateca still has the plates, while the other models have saved on them.
Edit: On your picture, the bracket looks slightly different. It might be that these plates don't actually fit after all. Best to take photos of the bare calipers during a tyre change and compare them with those from the GTI and others.
