Brakes make noises
peterpan007
Hello dear Cupra community.
We have been driving a Cupra Terramar with 204 PS pure petrol since 15.01.26.
The brakes make rubbing noises during every braking process, regardless of speed, as if you have washed your Cupra and there is surface rust on the brake discs that needs to be worn off first.
Is that normal?
Is it the same for you?
Regards, Peter
Hallo Peter, leider ja. Bei mir, wie auch bei anderen User hier (oder in dem anderen Forum) ;) . Komischer Weise aber nicht bei allen. :unsure:
Kommt bisschen drauf an. Wenns sehr feucht ist draussen, dann reibt meiner auch bei den ersten 2, 3 Bremsungen. Dann gehts besser.
I can sing a song about that too. Since last winter, my vehicle has also been making the grinding noise—especially at the start of a journey. It was particularly bad after the road was heavily salted and wet, and the vehicle had been parked for a day. When setting off, the car briefly locked up and a metallic bang was heard. The brake had seized. A picture says more than a thousand words about the quality of today’s brake discs.
Ouch, that’s intense how the windscreen looks. I also had many trips on roads that were heavily salted at times. But the windscreens never looked that bad before.
The quality has never been good. With our Ateca, the predecessor of the TERRAMAR, they had to be replaced at the first MOT, all four of them!! Despite several heavy braking incidents every now and then. You just can’t believe it.
