Car wash & power-operated tailgate
Philzstift84
Gesundes Neues,
eine Frage an die erfahrenen Besitzer einer elektrischen Heckklappe, gibts in Sachen Waschstraße etwas gesondert zu beachten, dass diese nicht versehentlich öffnet während des Waschens?
Dankeschön
Well, I don't drive a Cupra yet, but I can report from several years with another vehicle that the electric tailgate has never accidentally opened unintentionally via the "foot" sensor.
Hi,
I can confirm that once the engine is running, I cannot open the tailgate with my foot either; it was like that with my Tarraco and is now the same.
Regards
... the question was about a car wash tunnel, not a car wash facility ;) :ROFLMAO: :ROFLMAO: :ROFLMAO:
It shouldn’t be a problem for either that something accidentally opens here. But with all the little issues that have been pointed out here in the Cupra forum regarding the electrics, I wouldn’t be surprised if there were cases like this after all. ;) :ROFLMAO::ROFLMAO::ROFLMAO:
As a precaution, you can probably disable this function as well.
@Gand-Alf why is the engine off?
Until now, whenever I drove through, I always left the engine running 🤔
@Melfinos
So far, I haven't found any option for that in the settings 🙈
Take a look on page 121 in the corresponding book for "Easy Open" ;)
Whereas at our car wash you’re supposed to switch off the engine.
But don’t make me any more scared that something like that could happen. 😱🤣
I always get nervous when I put the DSG in N and then have to make sure the hill hold assist is deactivated.
It's all in the "Forbidden Book", you just have to read it :rolleyes:
As for the car washes, it's also in the owner's Manual*: ignition off! I would be more worried about the rims, especially with the 35-profile tyres, to make sure the rim edges don't get damaged.
I have already driven many different cars through various car washes – never had any problems with it so far.
For safety and peace of mind, after switching off the engine and then turning on the ignition, you can make sure that the vehicle is locked.
That way, neither the fuel flap nor the tailgate can unlock during the car wash.
Now, purely from a logical standpoint. When we drive with the Cupras, the car locks itself (provided it has been set up that way). So no one from outside can get into your car. When you switch off the car, the doors are still locked. The central locking only unlocks the doors when you get out. Because of this, the tailgate should actually remain locked if you stay inside. Or is it different with the electric tailgates? 🤔
No, that's normally how it is.
That's why I pointed out that you can check just to be safe.
It could be that you quickly grab something from the boot again, don’t drive faster than 15 km/h until you get to the car wash, and the car is unlocked.
It's all very "theoretical", but a quick glance to be sure doesn’t hurt :)
The problem, at least with the ST, is the Easy Open function, meaning opening by foot kick. The key is sufficient for this even when the vehicle is locked, as long as it is close enough
Therefore, it is safer to switch it off.
With portal car washes, this is definitely not an issue, as you are far enough away from the vehicle with the key, but in a car wash tunnel, you sit inside the vehicle with the key.
For the Hatchback, this is also not an issue, as there is no Easy Open.
The problem, at least with the ST, is the Easy Open function, meaning opening by foot kick. The key is sufficient even when the vehicle is locked if it is close enough.
I can hardly imagine that. That would mean that if Bonnie and Clyde can’t get in through the side door to nick the pack of chewing gum, they suddenly have a bright idea and gain access from the rear by foot kick? Well, I’m happy to be proven wrong, of course.
Dazu müssten B&C allerdings den richtigen Schlüssel dabei haben. Allerdings könnten sie dann auch ganz normal die Türen öffnen :rolleyes: :sleep:
Einfach mal in der BA nachlesen :cool::geek:
WTF? Ich sitze doch im Auto in der Waschstraße. Es geht doch darum ob sich die elektronische Heckklappe öffnen lässt von außen? Also ob easy open funktioniert, egal ob jetzt von Bonnie oder Clyde, oder der Bürste. 🤷‍♂️
