Leipold
I have had a Cupra Leon DSG 245 hp for a few days! Unfortunately, I have to say that the adaptive suspension, similar to my previous Seat Leon 150 hp (adaptive suspension), rattles just as much over uneven surfaces! It seems to be a serial defect for 7 years, but Cupra/Seat doesn’t really care! In my case, it was dismissed as not covered by the warranty (after several visits to the workshop and complaints by email) and was brushed off as "state of the art"! I thought the issue had been resolved with the Cupra Leon VZ, but I was wrong!
" State of the Art "
if "clattering" (especially from the suspension) were "State of the Art," then conversely, all vehicles that do not clatter would not meet the "State of the Art." :confused:
"State of the Art" is actually the wrong term. "State of the Art" refers to the state of science and research, e.g., "autonomous driving." Theoretically (according to the state of the art) feasible, but not yet mature and therefore not practical. The valid standard is more likely described by the "generally accepted rules of technology."
Hatte hierzu heute einen Servicetermin. Fehler ist bei Cupra bekannt und es wird (laut Mitarbeiter der Autohauses seit Mai 2024) nach einer Lösung gesucht, Bis dahin soll der Kunde vertröstet werden...
Hat jemand der FL-Fahrer mit DCC-Fahrwerk ähnliche Erfahrungen gemacht? Ich hatte ja gehofft, das dies behoben ist mittlerweile.
The road where I am is anything but smooth and quiet; at some potholes, you can already hear a rattling, or however you might better describe the noise. So I noticed the same here.
I'll join in here—why "reinvent the wheel"? With the ROC, it's usually a factory-fitted (much) too large axle boot. The problem is known (and too rare for a TPI). Initially, greasing is supposed to eliminate the noise (not the cause). After replacing the boots, the noise disappeared. In one case, the noise came from the play in the track rod, in another case from the strut mounts.
Hello everyone,
I also have a Cupra Leon ST with adaptive suspension and the same problems.
Here is the text of the last response.
"The noises in your CUPRA Leon ST are state of the art according to the manufacturer. Currently, there are no options for improvement. We very much regret that this complaint has occurred with your CUPRA Leon ST, but we ask for your understanding that we have no possibility to do anything remotely."
The dealership says they can do nothing.
Maybe we can make progress if we contact Cupra together?
Please get in touch if interested.
I actually find the noises very distinctive compared to other DCC suspensions. But well, I have to say that I expected more from the suspension. With other manufacturers, you really "glide" over the motorway. Here, there is hardly any noticeable difference.
Typisches VW, hatte ich mit dem Audi damals und mit dem Cupra auch. Hilft nur hartnäckig bleiben und darauf bestehen, es zu tauschen.
Ich frage mich wie es ohne DCC wäre 🤔
Schaut doch mal ins Motor-Talk Forum. Dort wird beim Tiguan 3 (2024) dieses Problem -massenhaft- angesprochen.... unter: lohnt sich das DCC Pro, gibt es bereits 26 Seiten mit über 380 Antworten !
Das Problem ist bekannt und es werden auch bereits viele Dämpfer getauscht. Ich glaube, dass etliche Cupra Modelle die gleichen Dämpfer wie der Tiguan verbaut haben.
Ich bekomme im März (wahrscheinlich) meinen Terramar und dort sind auch diese Dämpfer verbaut. Werde ja sehen.... LG aus Österreich
Kriege meinen Terrramar im April/Mai.
Wäre super, wenn du mich mal auf dem laufenden hältst, wie es bei deinem Terramar ist. Danke 🙏🏻
Fahre auch DCC im Leon ST Facelift, habe hier keine Geräusche bemerkt bisher. Wann und wie treten die bei euch auf? In welcher Situation und Fahrmodus/Dämpfung..?
Ich komme von einem Seat Leon ohne DCC und habe seit Januar den Cupra Leon 1.5 eTsi mit DCC!
Und ja…. Auch ich habe dieses rumpeln bei Unebenheiten…..Das ist echt nervig und klingt total billig! Als hätte ein Laie in einen 1er Golf ein China-Fahrwerk reingepfuscht!
Beim normalen Modus zu hören….. im Performance deutlicher! Kann das Geräusch nicht direkt beschreiben! Ein Dumpfer Schlag….. wie mit nem Gummihammer in den Radkasten…… so in etwa
@PlaysRaptor Hallo & Willkommen bei uns im Forum. Schön das du deine Erfahrungen mit uns teilst. 🍻 (y)
@PlaysRaptor ich hatte hier oben auch davon berichtet, muss dir wohl mitteilen, dass es wohl das "normale" Geräusch vom DCC ist.
War auch anfangs verwundert, aber ja, ist wohl leider so....
Bei mir gibt es auch keinerlei Geräusche in der Hinsicht. Egal ob hart oder weich eingestellt das Fahrwerk ist komplett ruhig.
Ich lese auch wieder vom "bekannten DCC Poltern" und bei mir kreisen nur die Fragezeichen ^^ Mein Jetziger ist der erste mit DSG und DCC, insgesamt total leise innen drin.
Wenn ich bei Unebenheiten ganz genau hinhöre ist da ein leises "bupp", denke das ist einfach der "Schlag" auf den Reifen. Halt so, wie wenn man von außen gegen treten würde, ist mEn nichts, was ich dem Fahrwerk anlasten würde und fern ab von laut oder gar störend.
So zumindest meine Erfahrung, lese es über wieder mal, kann es aber (zum Glück) nicht nachempfinden.
Kann nicht sagen ob wir dasselbe meinen …. Aber ich bin in meinem Leben ca 15 verschiedene Autos gefahren und habe nie ein derartiges Geräusch gehört…. Auch nicht wenn ichs mit dem von dir beschriebenen „Schlag auf den Reifen“ vergleiche! Das klingt ja trotzdem noch irgendwie komfortabel…..
aber das beim Leon mit DCC klingt einfach nur irgendwie billig….. als würde ein Dämpfer/oder Gummi fehlen
Zugegeben….. ich hatte noch nie ein DCC….. vielleicht ist das Geräusch ja Standard beim DCC 🤣
