Climate Control Problem at Different Outside Temperatures
cappuccino
Stammuser ★★
Normally, I always set it to around 22°C.
With cooler outside temperatures, the interior gets so warm that I have to lower it to 20°C and my feet are boiling.
On the other hand, with warmer outside temperatures, let's say from 25°C, the air conditioning blows so cold from the two center vents that you freeze while your feet stay hot. There’s no difference over a distance of 20km.
Do you have the same problem? It feels like the air conditioning is set to LO and no warm air is mixed in. What could be the cause?
I always have the climate control on and usually set it to 18°C-20°C.
The mode is set to Auto with one bar, and it actually blows continuously. One does not get the impression that it ever reaches 18°C!?
However, I cannot provide a long-term test, I've only driven it for 1500 km.
So I wasn’t really cold, I don’t have any figures in mind regarding the heating behaviour.
As for cooling, even at +30°C outside temperature and the setting at 21°C with Auto on level 1, it cools continuously without feeling frosty. At level 2, there is already a noticeable difference; it starts to go in the direction of your description.
I didn’t mention the level 🙈 I always have level 1 active.
Just now it was reasonably okay. Outside temperature 19.5°C, cloudy, car set to level 1, temperature set to 21.5°C. Despite the small difference, the two central vents blow fresh air, not strong. The right arm is correspondingly cool 😁
Almost nothing comes through the footwell and via the WSS.
Then just play around with the temperatures, 19.5 degrees outside doesn’t necessarily mean it’s only 19.5 degrees inside the car; with current daytime temperatures, it might be 23-24 degrees (or more) inside, and at a target of 21 degrees, it will of course cool down.
Edit: You can also direct the airflow straight to your feet, which you can do via the infotainment system just like before with the switches.
target
