Creaking noise from the driver door to the roof
Melfinos
Lebt hier ★
European-Union
I have had a creaking noise in the driver's door frame for some time now on uneven roads.
It can be reproduced, which is why I went to the dealer.
I don't want to share all the experiences here.
As a result, after a joint test drive, the workshop manager was able to reproduce the noise multiple times.
However, anyone who thinks that a solution and repair will happen immediately will be disappointed. First, it must be requested and confirmed by Cupra as a defect under warranty before the entire headliner will likely be replaced. The duration is likely 3-4 days until a response.
Let's see how long the examination at Cupra takes. I'll keep you updated.
Well, everything is puzzling to me. I think it often depends on the dealership and the commitment of the respective service advisor. Some people here drive a Cupra within the factory warranty and have to wait weeks for approval from Cupra when there is a defect. I drive a 5-year-old Cupra that I bought used from a private seller a year ago. The car has now had two defects in quick succession (Chiller = heat exchanger of the high-voltage cooling circuit defective and then rearview camera defective), and although my previous owner had the last two inspections carried out at an independent workshop and I drove my Cupra to a Cupra dealership that was completely unknown to me until then, Cupra covered most of the repairs as a goodwill gesture. And: The goodwill request was approved by Cupra on the same day it was submitted - absolutely no waiting time. What is going wrong here???
ich war bisher auch der Meinung, dass hier zwischen Cupra-Garagen und Cupra als Hersteller ein "direkterer Draht" zur Verfügung steht und damit eine schnelle Abstimmung erfolgt. Augenscheinlich ist dem nicht unbedingt so.
Wenn ich daran denke, wie lange ich auf eine Antwort vom Cupra-Support vor ca. 1 Jahr gewartet habe, dann wundert mich hier nichts.
4 Wochen vs. 4 Tage wäre dann zumindest der "schnellere Draht" 😀
Mal abwarten. Habe eher das Gefühl, das ich Ende nächster Woche wohl eher aktiv selbst nachfragen muss.
Zumindest habe ich das Auto in der Nutzung und es steht nicht in der Werkstatt bis zur Klärung.
Vielleicht liegt es an der Werkstatt, vielleicht auch an den Kosten. Ein ganzer Dachhimmel ist teuer, und sein Tausch noch teurer. Bei mir wurde das Klappergeräusch in der Nähe vom Griff am Dachhimmel innerhalb eines Tages abgestellt, aber es musste ja auch nichts getauscht werden. Daher denke ich, dass die Werkstatt die Kosten selber übernommen hat, weil sie überschaubar waren. Sonst hätten sie auch erst bei Cupra wegen Kostenübernahme angefragt. Keine Werkstatt will die teuren Reparaturen selber übernehmen.
aus der Richtung kommt bei mir auch das Geräusch. Warum der Werkstattmeister Cupra empfiehlt den gesamten Dachhimmel zu tauschen, habe ich nicht mehr gefragt. Ich sehe jedoch, das Sie den Himmel zumindest teilweise entfernt hatten. Die Spaltmaße sind nach der Aktion deutlich unsaubererer.
Ich gehe also davon aus, dass sie es angeschaut haben und nicht wie @Invio1 so einfach zu beheben ist.
Hmm, no idea what they did to mine, but it had an effect and I don’t see any difference from before. I wouldn’t necessarily accept uneven panel gaps after a repair either.
*Update*
Aktuell nichts neues vom Freundlichen. Irgendwie hatte ich das im Gefühl, dass ich selbst nachfragen und "drängen" muss.
mich stört es nicht mal, wenn es noch keine Rückmeldung von Cupra gebe, aber wenigstens der Freundliche hätte eine Mail schicken oder anrufen können, mit der Zwischeninfo, dass es eben noch keine finale Antwort seitens Cupra gibt.
* Update *
Today I received the information that the replacement of the headliner will be covered under the warranty. The new headliner has also already arrived at the dealership’s warehouse.
I will now leave my Cupra at the dealership for 2-3 days for the replacement. The appointment is set. 👍
* Update *
Tausch des Dachhimmels im Rahmen der Gewährleistung
Ich habe genau dasselbe Problem.
Die Griffe wurden schon getauscht und nun möchten sie die ganze Sache erstmal "unterfüttern" - bin gespannt ob das was bringt...
Werde aber mal andeuten, dass bei jemand anders der komplette Dachhimmel getauscht wurde. 🫣
Habe das Problem auch, hat unterfüttern das Problem gelöst?
@Pavel das kann ich Dir leider erst sagen, nachdem es gemacht wurde - Mitte April zum ersten Ölwechsel (halte einen einjährigen Rhythmus für am besten).
Ich habe meinen jetzt zum zweiten Mal in der Werkstatt zum unterfüttern. Habe gehört, dass manche sogar den Dachhimmel getauscht haben…
Meiner war auch schon wegen dem Geräusch in der Werkstatt. Habe das Panoramadach und da hatte sich eine Kunststoffleiste gelöst. Nach 10k km ist das Geräusch nun wieder da :rolleyes:
Hängt aber bei meinem Pano davon ab ob das Rollo / Dach offen oder zu ist. Wird wohl nen Problem damit sein, dass das Pano mit einer Vorspannung eingebaut werden muss.
I also had the noise. I then went to the workshop where they did some soundproofing. After that, it was better for a short time, but then it started again. During the second appointment, the locksmith from the workshop took a spin and heard it right away. They did something again, and since then it has been completely quiet. Unfortunately, I don't know exactly what was done, but I can find out on Monday.
Also habe heute einmal nachgefragt. Bei mir lag das Problem beim Angstgriff. Dieser schiebt sich mit zwei Metallklammern unter den Himmel, zwischen diesen Klammern und Himmel kommt es zu einem "normalen" Abstand. Ist dieser aber zu groß/klein, kommt es zu einem knacken.
Bei mir wurde der Himmel vorne links gelöst, es wurde Filz an die Oberseite des Himmels angebracht, so kommen die Metallklammern direkt an den Filz welcher das Geräusch verhindert.
Vielleicht ist das ja für den ein oder anderen hilfreich.
Klingt nach dem, was bei mir gemacht wurde. Ich habe da nicht nachgefragt, Hauptsache es war wieder Ruhe.
Bei mir ist auch nach dem zweiten Mal nachbessern jetzt endlich Ruhe. Gerade bei Kälte hat man es bei mir extrem gehört.
Jetzt poltert nur noch das DCC.😁
* Update *
Ich werde euch berichten, wenn ich das Fahrzeug diese Woche wieder abholen darf/kann.
* Update *
Der Dachhimmel wurde getauscht. Fahrzeug konnte ich heute direkt wieder in Empfang nehmen.
Positiv überrascht hat mich tatsächlich die schnelle Umsetzung.
Montag morgen Abgabe und heute Abend abgeholt.
Auf meiner Fahrt von ca. 15 km nach Hause konnte ich kein "Knarzen" im Holm mehr wahrnehmen. Es hat meiner ersten Einschätzung her tatsächlich was gebracht, da ich vorher mittlerweile ja fast ständig bei jeder Fahrt das "Knarzen" hatte.
Da ich in den kommenden Tagen und über das Wochenende einige Kilometer fahren werde, kann ich mir das noch auf "Langzeit" anschauen/anhören.
Sollte ich mich hier in den kommenden Tagen nicht mehr dazu äußern, dann war alles erfolgreich und nachhaltig.
Have the noises completely disappeared for you now or have they reappeared? I have the same problem; in winter and when the roof is open, they are the loudest. On Monday, I have the service appointment for the oil change and I would have brought this up then.
