Cupra could take a page from Dacia and Renault.
Ponyhof1
Hmmm... You also have the Assi button on the steering wheel... Left thumb, right thumb, done. It's not that much more complicated, is it?
Reactions: ekm
What do you mean by the "Assi button"? Is there a key combination that does something specific?
Left side of the steering wheel. Assistance button. Press it. A list of assistance functions appears in the left area of the speedometer. You scroll through with the right thumb wheel and press to turn each one on/off.
For example, Lane Assist is just left thumb, right thumb, left thumb (that's how I do it anyway, because I find swiping on the screen too annoying AND when the Lane Assist complains again because it interprets the shadow of a guardrail as a lane marking, I prefer to have both hands on the wheel and my eyes straight ahead).
Reactions: ekm
Press the assistant button (circle with car), then a dropdown bar appears in the cockpit, where you can select the position with the wheel on the right and activate or deactivate the position by pressing the wheel or switch between ACC and TA.
Edit: Too slow, but with both explanations, it might be even easier to understand.
Here was nonsense
And while the eyes are focused on the menus, it goes bang.
I believe that the other so-called "affordable" brand has put more thought into what the customer wants. Simple operation within the framework of the law.
And if I can turn off the pre-selected assistance systems with a double-click or a long press on a button, that is very convenient. Without having to look at any screens. I expect Cupra to make the most of the legal framework. If everything is switched back on after starting the engine, that is also compliant.
You don't need a menu for that. Just look at the speedometer and that's it.
Of course... There's always room for improvement. Why not write a suggestion to Cupra!
Reactions: ekm
The legislator, who came up with the fun, basically doesn't want it to be turned off quickly and easily; otherwise, they could have saved themselves the trouble.
And with a certain routine, the described process can also be done without having to look at the cockpit (which you still have to do if you want to see how fast you're going, whether there's still enough range left, etc.). You can also do it completely safely just before starting to drive.
Maybe we shouldn't go wild over such a small thing, like making a fuss about a pony farm here. ;)
No matter how you look at it. The others just did it better. At Cupra, they thought about having the option to turn them off individually with a swipe down. That's fine, they recognized the problem and created the possibility to make it "easier" already. Legally, however, it is possible to make it even simpler. There just need to be enough people who want that. There doesn't even have to be any changes to the hardware.
Why should it go bang??? Just deselect the junk BEFORE DRIVING!!!
My habit: Get in, turn on the ignition, press OK in the infotainment or wait until it goes away by itself, buckle up during this time and possibly stow small items in the center console, wipe down and turn off S/S + warning, start the engine and off we go. Sometimes also just start the engine directly and then wipe down and turn everything off.
