Cupra Formentor VZ e-Hybrid 272 PS – Recurring error message: "Hybrid system not functioning correctly."
Svenja
Hello everyone,
I hope someone here can help me with similar experiences.
I purchased a Cupra Formentor VZ e-Hybrid with 272 PS (first registration 01/2025, currently about 33,000 km) on October 23, 2026.
Just one day after the vehicle handover, the yellow error message "Hybrid system is not functioning properly" appeared for the first time.
Regarding the error pattern:
The error message has occurred multiple times now, but always under quite similar conditions:
  • The vehicle is in hybrid mode.
  • The function "Maintain Battery Charge Level" is activated.
  • The combustion engine is already running.
  • The message appears during stronger acceleration, especially at higher speeds on the highway (around 120–150 km/h).
  • Under normal driving conditions or in hybrid mode without the activated hold function, the error has not occurred so far.
  • The vehicle continues to drive normally despite the error message, and the driving modes can still be switched.
  • After turning off and restarting, the message initially disappears again.
The first occurrence had the battery partially charged. In a subsequent incident, the battery level was around 98–100%. Additionally, the regeneration was set to "strong."
Previous workshop stay:
On October 27th, the vehicle was taken to a Cupra authorized workshop through the selling dealer.
After consulting with Cupra, an issue with the climate control unit was initially suspected. Later, I was informed that the air conditioning compressor was defective
On November 12th, I was able to pick up the vehicle again after about two weeks.
Unfortunately, the error occurred again on November 15th – even twice within a few minutes (around 8:45 PM and 8:55 PM).
Again, this was in hybrid mode with the "hold battery charge" function activated and during stronger acceleration.
I am now wondering whether the cause actually lies in the area of climate control or if there might be a problem with the power demand or the interaction between the combustion engine and the electric motor.
My questions to you:
  1. Has anyone encountered this error message with the Formentor VZ e-Hybrid with 272 hp?
  2. Do you also notice it during stronger acceleration or when the "Maintain Battery Charge" function is activated?
  3. What cause was identified in your case?
  4. Was the error permanently fixed, and if so, what repair was done?
The vehicle has now been claimed again at the dealer. Since the error occurred immediately after purchase and persists despite repairs, I am of course quite disappointed.
I would greatly appreciate any experiences, especially from drivers with the newer 272-PS hybrid variant.
Thank you all in advance!
Does the electric motor engage during acceleration (so is the boost recognizable as a color indicator in the tachometer or do you notice that only the combustion engine is accelerating and the e-boost is missing)?
Do you always charge the vehicle to 100%?
My Leon PHEV VFL had almost the same problem, and it turned out that the so-called chiller was defective. The chiller is the heat exchanger that separates the refrigerant of the air conditioning from the coolant of the high-voltage battery's cooling circuit. In my case, the fault was initially not found and then became obvious when the coolant from the high-voltage battery's cooling circuit evaporated into the air conditioning's refrigerant circuit. Therefore: The sealed expansion tank of the coolant (high-voltage circuit) in the engine compartment was completely empty. I would keep an eye on the tank or the level of the coolant.
The E-Boost activates for this. At lower speeds, the error message does not appear either.
I haven't had the vehicle for long (and therefore haven't charged it often yet). When the error occurred yesterday, it was 100% charged.
Unfortunately, I don't know how the previous owner charged it.
It's best to give the note from Cupra-Klaus to the workshop, then they can check it. If the boost works, at least the hybrid function is given.
As for charging, 80% is generally recommended. 100% is actually only advisable if the vehicle is moved immediately afterward (that's how it should have been formulated in the Manual*, in my opinion). Charging above 80% has also led to system errors in some cases.
Thank you very much - good to know. I wanted to drive home for 45 minutes right after that. That's why I charged fully - and then the error came back again.
High Voltage System Cooling Error.
@Killboy
As a VFL, it can't be a new vehicle. I bought the car from a friend almost two years ago, and I am the owner of the vehicle. So no leasing, financing, or anything like that.
