It seems that the 12V battery is only sufficiently charged when the combustion engine is used regularly. Pure driving and charging in E-mode apparently isn't enough. At least that's my assumption. I also had my issues with returning to E-mode, even though the HV battery was more or less full and the V-Max was far from being reached (30 km/h). Whether and how the 12V battery is also charged directly during the HV charging process by the wallbox??? The 12V battery is located, as already described, under the loading area, and there is an emergency release for the charging flap under the hood.
The 1.5 TSI in the PHEV, to my knowledge, does not have an alternator, so the 12V battery is actually not charged by the combustion engine. The 12V must be charged by the HV battery. A "new" theory from Cupra is that you should unplug the charging cable promptly after the charging process, otherwise the 12V battery will be drained. At least that's what was stated by the Cupra workshop in another forum. I also had that "problem" with returning for a while (2x for a few days). As soon as the combustion engine started, it briefly displayed "longer engine run needed." I could only enter eMode by restarting the car. Apparently, this has to do with the OPF that quickly clogs up with mostly short uses in the PHEV. I then drove on the highway, and then it was quiet again for a few weeks, and the vehicle switched back and forth between Hybrid and eMode without problems.
Reactions: ekm
So, a brief interim report: the tow truck driver couldn’t manage it. My wife was there, but she didn’t turn the key enough, and everything was too heavy anyway. The car wouldn’t start, at best with jump-start assistance you could only roll down the window and put the gearbox in neutral. The gentleman was a bit pissed off because he doesn’t see any payment for this yet. He’s coming back this afternoon and wants to try again with me then. As it stands, all in all, it’s more than frustrating. When asked if my wife should quickly fetch the neighbours, he didn’t want that either. It remains exciting, and I’ll report back as far as desired.
@Tygulav But no alternator somehow sounds strange to me. What do people who drive the PHEV do when the battery isn’t charged? It can’t be that there’s no alternator to start the combustion engine, or that there isn’t even a warning on the display like “Battery low” or something. Even the A-Class showed that early on with my wife, because then the start/stop wouldn’t work anymore and the battery became too weak. There are also many who drive the PHEV without charging and have no problems. But well, I have no idea, but I would still have thought there would be an alternator, since when maintaining the battery, the combustion engine can also recharge the battery—and with what, if not an alternator?!
The HV is not charged by an alternator when "maintaining charge" but rather through regeneration. If someone never charges their vehicle, they will eventually drain the 12V battery and also cause significant damage to the HV battery. You can take a look in your engine compartment. Where the alternator sits in the 1.5 eTSI, there is some box in the PHEV. Maybe a converter to charge the 12V battery? Or the thermal module for heating. I've read a few times that the PHEV apparently has no alternator.
Edit: By the way, I drove with the combustion engine several times before the 12V battery was empty.
Yes, all good, but I still can’t explain it. The car was charged regularly, the combustion engine starts more often because I drive a mountainous route, and it then switches on the combustion engine for support. I bought the PHEV to drive as often as possible with the electric motor, but the fact that this is exactly what’s now bad just doesn’t make sense to me, sorry. Then it really must have been an absolute bad purchase on my part....
Also der PHEV hat keine traditionelle Lichtmaschine, sondern einen Generator, der die Batterie auflädt und die elektrische Energie für den Antrieb bereitstellt. Der Verbrenner wird normalerweise über den eMotor gestartet.
Mir ist es auch ein Rätsel wie dann trotzdem die 12V Batterie tiefenentladen sein kann, wenn man vorher öfters den Verbrenner aktiv hatte. Und vor allem, wieso dann die Alarmanlage davor ständig losgeht und dabei lauter komische Fehlermeldungen im Display angezeigt werden.
Ok, danke dir für die Aufklärung, aber dann bin ich nun auch etwas schlauer und warte mal ab, was die Werkstatt sagt, der Abschlepper will es gleich nochmal versuchen bei mir den aufzuladen, hänge aber immer noch auf der Arbeit, mit dem Autohaus wo er nun hin kommt (nicht mein AH wo ich ihn geholt habe), wusste aber von Cupra nun auch nicht Bescheid dass ich ein Leihwagen haben möchte, sprich die haben keinen mehr frei und hat alles mal wieder nicht so geklappt, wie man es versprochen hatte… 🙄
Bin ich froh, dass ich micht nicht doch nochmal auf den PHEV umentschieden habe.😬
Ich drücke euch die Daumen, dass sie das (nun häufiger vorkommende Problem) in den Griff bekommen.✊
So, Abschlepper war nun wieder da, komischerweise (ich kanns nicht genau sagen, da ich noch auf der Arbeit hänge) sprang er nun ganz normal mit Starthilfe an, der Verbrenner sprang auch normal an. Vermutlich hatte er das nicht richtig angeklemmt oder so. Der Wagen konnte nun aus eigener Kraft drauf gefahren werden. Mal sehen was die Werkstatt "heraus findet" oder zu sagen hat... Auf der eine Seite bin ich froh, dass da scheinbar nichts defekt ist, und der Motor und so funktioniert, aber das mit der 12V Batterie sollten die echt mal schnell beheben.... Werde euch hier berichten, denke aber mal, das ich frühestens morgen was von der Werkstatt zu hören bekomme.
So, wie versprochen berichte ich für alle die mal das gleiche Problem haben sollten oder so, was ich aus meiner Sicht sagen kann.
Gestern hatte sich leider keiner mehr bei mir gemeldet, dafür kam heute Morgen der Anruf von der Werkstatt, dass mein Auto fertig sei. Auf die Frage was damit sei, meinte er, das es ein Problem wohl gibt, wo die HV Batterie die 12V Batterie leer saugt. Die haben auf Anleitung* von Cupra nun das Problem wohl gelöst und mir eine neue 12V Batterie eingebaut. Ich muss zum Glück nichts zahlen (wäre auch zu schön bei einem 4 Monate alten Wagen). Ich habe dann noch gefragt ob das Problem denen bekannt ist, ja, ich war nun der 3 neue Wagen bei denen in der Werkstatt, die kannten das Problem wohl schon und hatten auch welche vor mir mit dem selben Problem. Zur Zeit bin ich noch auf der Arbeit, kann ihn also erst heute Nachmittag abholen, werde aber nochmal nachfragen was im Detail die da nun genau gemacht haben. (Nicht das ihr hier selber Hand anlegen sollt, aber um das Problem vielleicht besser zu verstehen)
Bin froh das es nun nicht all zu lange gedauert hat, werde mich heute Abend bei euch melden und auch nochmal ein Bild von meinen Versionsnummern machen, um besser vergleichen zu können, ob sich da vielleicht etwas geändert hat.
LG und bis später!!
Klasse, ich drücke ganz fest die Daumen, dass das Problem/ die Ursache damit nachhaltig behoben wurde..🤞🍀
So, ich musste nun 40 Minuten zur Werkstatt fahren von der Arbeit aus, als ich ankam waren die Jungs aus der Werkstatt gerade im Feierabend, aber ein anderer konnte mir ein wenig erklären. Ich habe ihn nun wieder, es wurden andere Parameter in der Steuerung eingestellt und noch ein Update gemacht, alles nach Anleitung* von Cupra, die Batterie (12V) wurde erneuert und er wurde von außen nochmal sauber gemacht. Ich habe auch nochmal nachgefragt ob ich irgendetwas falsch gemacht habe oder ob man was beachten sollte bei den Modelle? Er meinte nein, das ist wohl klar ein Fehler in der Programmierung oder so. Wenn’s aber nun öfters auftritt, frage ich mich, warum Cupra keine Rückrufaktion macht? Naja, erstmal bin ich beruhigt und vor allem gespannt auf die nächsten 4 Monate, die Rückfahrt war wieder alles normal und wenn mir was auffällt, berichte ich euch. Anbei das Bild vom Boardcomputer, glaube aber, da hat sich nichts geändert.
ich denke auch, dass du hier nichts sehen wirst. Die Updates der Steuermodule, die im Fahrzeug verbaut sind, siehst du ja nicht über das Infotainment.
unabhängig davon finde ich es nicht gut, dass dies erst passieren muss und der kunde diese negative Situation hat, bevor an der Programmierung eine Parameteränderung und Optimierung erfolgt.
Eine Rückrufaktion wäre da sicher wünschenswert
wie @Ice-Mark schon sagt, werden sich Hersteller wahrsch. erst Gedanken machen, ob ein Mangel die gleiche Ursache hat, wenn ein paar KFZ damit in der Werkstatt waren. Werden es mehr Fälle, wird m.E. zunächst eine TPI erstellt. Das könnte evtl. sogar schon der Fall sein, wenn @Ice-Mark von "nach Anleitung* von Cupra" schreibt. Bei Rückrufen bin ich mir nicht sicher, ob hier nur sicherheitsrelevante Mängel aufgeführt sind, die ja vom KBA überwacht werden.
Der hier beschriebene Mangel ist jedenfalls nicht in der Rückrufdatenbak des KBA gelistet.
Na, jedenfalls ist der Mangel behoben und bei Cupra bekannt. 👏
Danke für eure Anteilnahme, ich glaube, dass der Fall immer öfters auftritt. Ich musste wie gesagt 40 Minuten nach Mayen fahren, also ein Ort, der nun auch nicht der größte ist (sry wenn ich damit jetzt hier jemanden verärgere 😅 ), aber wenn die hier allein schon den Fall paar Male hatten, weiß ich nicht was ich davon halten soll.
Für mich persönlich klang das Ganze auch so, als wenn hier der Work around von uns Kunden nun auch erstmal die nächsten Monate "getestet" wird. Es bleibt abzuwarten ob ich nun meine Ruhe mit zumindest dem Problem habe.
Für mein empfinden, denke ich, dass das Auto hier nun auch besser den Ladestand der HV Batterie hält, bin die zwei Fahrten nun im Hybrid Modus mit Batterie halten gefahren, kann mich aber auch täuschen. Werde hier die Tage wieder mal etwas ausprobieren.
Dann drücke ich mal die Daumen!
Bei mir ist die Klageschrift heute raus gegangen.
Ich würde mich natürlich sehr freuen wenn das Autohaus noch einlenkt, sonst sieht man sich vor Gericht wieder.
Auto wurde heute zum letzten mal bewegt, solange es noch keine Entscheidung gibt bleibt der Leon auf dem Hof stehen. Zum Glück haben wir noch einen Zweitwagen.
Wie ist der Stand ?
Die haben auf Anleitung von Cupra nun das Problem wohl gelöst und mir eine neue 12V Batterie eingebaut.
wurde eine baugleiche Batterie eingebaut oder z.B. eine EFB gegen eine AGM getauscht ? Weißt Du zufällig, ob hinter der "Anleitung* von Cupra" eine TPI steckt ?
Wie dem auch sei, frage mich nur, da das (Dein) Problem offenbar gelöst ist, auch @Pat89 helfen könnte obwohl das "Verfahren" einen Schritt weiter zu sein scheint. Aber vlt. gibt es eine zeitliche Überschneidung der Ereignisse, so dass man das Rad noch auf techn. Ebene zurück drehen kann.
@Gand-Alf nein, aber kann gerne mal alles aus dem Kofferraum raus fummeln, da sollte ja hinten dann irgendwo die Batterie zu finden sein, kann euch dann gern mal ein Bild machen. Eine TPI kann ich dir leider nicht sagen, werde aber vielleicht mal bei der Werkstatt nachfragen, ob sie mir den Bericht oder so zuschicken können.
Hatte Pat nicht einen reinen Verbrenner? Glaub nicht das es vergleichbar mit meinem Problem dann ist?!?
Alles gut, dafür haben wir doch unsere Gemeinde im Forum, um sich ggf. untereinander helfen zu können, und wenn das dann noch einem hier weiterhilft, mache ich es gerne. Zwar blöd das es mich nun getroffen hat, aber naja, ich hoffe mal das ich nun etwas mehr Ruhe habe und im Mai mit dem in den Urlaub fahren kann.
