Cupra Leon ST 2.0 TDI Taiga Grey
Welcome! You have been invited by rene18m to join our community. Please click here to register.
tim9r
Hello everyone,
it's finally my turn as well. The day before yesterday, I received the email that the vehicle has arrived. I've already received the first pictures from the seller 😍
Right away, a question: are there special covers for the wheel nuts? In silver, they look quite unsightly.
As soon as I have the vehicle, there will be new pictures.
Best regards 😊
Da sind standardmäßig schwarze Kunststoffkappen dabei. Ich denke die kommen bei der Aufbereitung noch dran😉
Most beautiful colour for the car👌🏻
Wishing you always a good and safe journey 🍀
Congratulations, and have a good trip.
What makes the diesel so much better in comparison (to which) eTSI?
Thank you ☺️
I previously drove a Golf 8. It’s hard to describe, but with the Golf, for example, the car always jerked a little when starting off. The diesel now moves forward immediately when starting and doesn’t have this “slow start” feeling.
The range is completely different compared to the diesel, and the car drives noticeably smoother at higher speeds and doesn’t rev as high.
The Golf 8 is indeed comparable to the current eTSI in the Leon. It doesn’t sound like there are huge differences, but enough that, due to the points mentioned, it’s noticeably more pleasant for you to drive. What average consumption/range do you get with the diesel?
In my opinion, the criticised points with the eTSI mainly stem from the throttle control. You can tell it’s definitely possible (when it works optimally), but the throttle pedal reacts differently to the same “commands” from the foot; sometimes it’s surprisingly direct and with the right ratio of pedal travel to propulsion, but other times it feels like the system can’t decide
Muss auch sagen, dass Leistung da ist wenn man weiß was man will. Aber ich geben @ekm recht, das verbaute Getriebe ist etwas zäh in den Entscheidungen.
Das Getriebe im 190ps 5F war da mehr auf Entscheidungsfreude getrimmt, weniger Überlegungszeit und schnellere Reaktion.
Aber wie gesagt man muss auch etwas mit dem Auto mitfühlen und es verstehen,dann kann man denke ich aus allem noch etwas herausholen.
Reactions: ekm
@tim9r allzeit gute Fahrt und die beste Farbe die geht 🤩👍
Kannst du mir die Schlüsselnummer deines Fahrzeugs verraten? Ich suche die vom 2.0 TDI als Nicht Sportstourer... Sollte eigentlich 7593 / ASU sein, diese ist aber ab 2023 vergeben.
