Cupra Leon ST VZ 333PS MY2026 Magnetic Grey Metallic
kuchen25
Hi everyone,
I picked up the Leon Kombi yesterday. So far, the impression is excellent. The typical issues one often reads about don’t seem to be present at first glance. The boot lid switch works. The exterior mirrors don’t “shake.” The drivetrain resonance (probably at around 80km/h) isn’t really noticeable. The panic handle makes no noise. The ambient lighting hasn’t flickered so far, even when starting the ignition/engine immediately. The side sills are flush with the bodywork. Connecting to the "My Cupra" app worked on the first day. The world globe hasn’t turned grey yet (after two days). So far, no assistance system has failed. Only the 12V battery was reported as “weak” at handover according to the system, but it wasn’t weak afterwards (probably due to being left too long in storage, as it was produced at the beginning of October 2025).
In my opinion, it’s relatively quiet at 130km/h (not on A6 level, but still good). The Sennheiser system is, in my view, extremely good. The damping in Comfort mode is also pleasant. The infotainment runs smoothly. CarPlay connects and starts almost instantly. The speed warning sound is relatively subtle, and also pleasant. Even the 230V socket in the boot was present, despite the car being a new EU vehicle from Denmark. The interior feels very premium, at least in the front. It has a comfortable entry. I also like the black contrast elements (instead of grey, change to MJ2026). The car is also quite easy to see out of, you can assess it well from all angles. You can also feel the engine’s performance, even though I haven’t driven it extensively yet.
What surprised me most so far is the fuel consumption—I expected higher figures. On the first return trip (80km/h on the motorway), it was 5.9L/100km. On the second trip (motorway, between 80km/h and 140km/h, 1500rpm and 2500rpm), it was 7.4L/100km (average speed was 100km/h).
It was ordered mid-July 2025 as a new EU vehicle, ready for collection in Germany by early December 2025, and picked up in mid-December 2025. So it took 4.5 months. Unfortunately, the Danish Cupra dealer couldn’t enter the handover inspection into the system due to IT issues (allegedly), so I’ll have to follow up on that myself. However, Cupra confirmed that the manufacturer’s warranty is unaffected by this. As delivery accessories:
  • Breakdown kit (VW/Cupra, tyre compressor, etc.)
  • Dashboard folder with operating Manual* (in Danish)
For configuration: I opted out of the Matrix-LED headlights, as they could become very expensive if faulty after the warranty period. I also skipped the panoramic roof, as it’s prone to leaks quite often. Both would have been great, but weren’t essential for me.
So far, really satisfied.
Funktioniert die Öffnung des Kofferraum mit Fuß? Funktionierte bei uns noch nie.
Jetzt nach 2500km ist das Keyless System komplett ausgefallen und die rechte Türverkleidung vibriert bei lauter Musik.
Nächste Woche ist Termin bei Cupra.
Das Öffnen mit dem Fuß funktioniert bei mir meist nur, wenn ich erstmals auf das Fahrzeug zugehe und lediglich die Lichtanimation angeht. (Keylessgo für alle Türen aktiviert) aber maximal in 7/10 Fällen.
hinten links vibriert es neuerdings auch.. bin gespannt was dein Werkstatttermin sagt
Ich glaube der Verbrauch ist auch nur auf Langstrecke auf der Autobahn machbar. Ich hatte jetzt kürzere Strecken (20km) auf Landstraße, da hat er sich heute 8,4L/100km gegönnt.
Ich hatte jetzt auch das erste Mal einen kurzen Ausfall der Assistenzsysteme wegen vmtl. leicht angetauten Sensoren, das ist aber nach 2min Fahrt wieder weggegangen.
Das Ambientelicht flackert aber weiterhin nicht, auch wenn man Motor sofort startet.
Also immer noch sehr zufrieden bis jetzt.
Wir fahren unserer eher mit ca. 11 Liter, fahren aber auch viel Kurzstrecke unter 10 Liter bin ich bisher nur bei Urlaubsfahrten gekommen.
Wenn mn den VZ rollen lässt, sind die Verbräuche schon drin. Ich hatte kürzlich eine recht gleichmäßige Überlandfahrt von ca. 65km mit ca. 80 km/h Durchschnitt und hatte dann 7,8l stehen. Allerdings auf den letzten 3 km, die dann Autobahn waren, hat der rechte Fuß kurz gezuckt und schwupps waren es 8,2l Durchschnitt 😁
Ich habe jetzt schon die ersten 1.000km rum und bisher immer noch nur die zwei Mini-Fehler: 12V Batterie schwach bei Auslieferung, einmal waren bei knapp über 0 °C die Assistenzsysteme die ersten zwei Minuten nach Start nicht verfügbar.
Die letzten Fahrten waren immer bei Dunkelheit, das Ambientelicht hat nicht einmal geflackert, obwohl ich Motor/Zündung immer sofort/gleichzeitig starte. Also das scheint das MJ2026 / Software 2768 wohl gefixt zu haben?
Da ich jetzt beim Einfahren langsam die Drehzahl gesteigert habe und die Drehzahl immer variiere, habe ich jetzt auch 8,9L/100km auf der Autobahn geschafft mit Geschwindigkeiten zwischen 90km/h und 160km/h. Das ist aber eine ziemlich ineffiziente (ungleichmäßige) Fahrweise würde ich sagen. Aber die Autobahn scheint er zu mögen.
Ich bin jetzt bei ca. 1.500km und so wie bei meinem Vorgänger dem Seat Leon ST 5F mit 179PS fällt mir auch beim Cupra auf, dass es einen erheblichen Unterschied macht, ob ich auf der AB mit 130kmh oder 140kmh fahre. Da liegt schon mal gut 1l dazwischen. Einfach mal probieren.
Man muss aber nicht immer gleichmäßig fahren 😅
Mittlerweile habe ich 1.500km runter und er macht immer noch Spaß.
Bei längeren Standzeiten draußen bei Minusgraden bekommt man relativ zuverlässig den Ausfall der meisten (vmtl. radarbasierten) Assistenzsysteme. Dauert dann ein paar Kilometer, dann geht es wieder (obwohl die Radareinheit ja seit Golf 8 nicht mehr beheizt ist, anscheinend reicht Fahrt).
Was mir dazu aufgefallen ist: Wenn man das Radio etwas lauter macht und sehr bass-lastige Lieder kommen, dann kommt ein Vibrieren von der B-Säule auf der Fahrerseite. Allerdings auch temperaturabhängig scheint mir. Ich hab mal feste gegengebollert, dann war es weg. Mal schauen.
Ambientelicht habe ich immer noch nicht einmal flackern gesehen, das scheint mir gefixt worden zu sein.
Beim Verbrauch schaffe ich bei nicht so langen Fahrten (< 20km) mittlerweile bei Minusgraden auch relativ zuverlässig 9L/100km. Je länger die Fahrt, desto niedriger wird der Verbrauch bei mir, auf der Autobahn auch gerne 7-8L/100km (bei Durchnittsgeschwindigkeit 100km/h).
Den Spurwechselassistent habe ich nun auch mal eingeschaltet (war ab Werk ausgeschaltet). Ist ganz nett, aber so sinnvoll jetzt auch nicht, er braucht ganz schön lange.
Das Grau Metallic ist auch relativ gütig in Bezug auf Schmutz, mein uni-weißes Auto vorher war da die Hölle.
Macht Spaß das Ding :)
Mittlerweile sind nun 2.000km runter und immer noch sehr zufrieden mit dem Auto.
Mängel die bisher aufgefallen sind:
  • Vibrieren und hörbares Summen der Türverkleidungen bei Fahrer- und Beifahrertür bei ca. 50% Lautstärke, Sennheiser Immersion 2/3 (Standard) und basslastigen Liedern (z.B. "Can't Believe It - Flo Rida, Pitbull" direkt zu Beginn). Fahrertür deutlich schlimmer als Beifahrertür. Wenn man mit seinem Ellenbogen gegen das Alcantara drückt, ist es weg.
  • Bei jedem ersten Fahrzeugstart am Tag kommt die Meldung "Neue Benutzereinstellungen verfügbar". Manchmal drücke ich Ok, manchmal Abbrechen, merke nichts.
  • Ausfall der frontradarbasierten Assistenzsysteme (z.B. Travel Assists) bei längeren Standzeiten draußen bei Minusgraden. Löst sich auf nach ca. 5km Fahrt oder durch manuelles Freikratzen.
  • Keyless schließt das Fahrzeug nie ab beim Weggehen, also wirklich nie, vermute daher fast ein Bedienungsfehler von mir. Aufschließen funktioniert meistens (ca. 90%).
  • LED-Scheinwerfer beschlagen hin und wieder, verdunstet aber ohne Tropfenbildung. Ist aber glaube ich normal bei aktuellen Fahrzeugen, weil die Scheinwerfer nicht dicht sind und die LED zu wenig Hitze erzeugen.
  • Fahrzeug hatte kein Wischwasser bei Auslieferung, selbst aufgefüllt.
  • Fahrzeug hatte keine Übergabeinspektion im Digitalen Serviceplan (DSP) eingetragen, mittlerweile nachgeholt durch erstausliefernden Vertragshändler aus Dänemark.
Mich stört eigentlich nur der erste Mangel, mit dem geht er jetzt in zwei Wochen zur Cupra Werkstatt auf Garantie. Sie wollen die Türverkleidung abbauen, nach losen Sachen und Clips schauen und ggf. Filz auslegen. Ich bekomme auch einen Ersatzwagen. Auch als EU-Neuwagen aus Dänemark. Ein flackerndes Ambientelicht hatte ich noch nie (MJ2026). Auch die wummernde Kardanwelle bzw. Torque Splitter bei 80 km/h habe ich noch nie wahrgenommen und eigentlich höre ich relativ viel (siehe summende Türverkleidung) und unsere Stadtautobahn hat überall 80 km/h. Die anderen Mängel v.a. von den Plugin-Hybriden und eTSIs hatte ich bisher auch nicht.
Positiv:
  • Der Motor (2.0 TSI 333PS EA888evo4 DNFF) hat wirklich ordentlich Kraft, merkt man insbesondere auf der Autobahn, wie viel Durchzug er auch noch bei höheren Geschwindigkeiten hat.
  • Der Verbrauch (siehe unten) ist finde ich völlig ok. Man kann gefühlt durch seine Fahrweise relativ gut kontrollieren, wie viel man verbraucht (und wie sehr man den Turbolader benutzt).
  • Der Sound vom Auspuff ist im Stand meiner Meinung nach angenehm. Es ist etwas da, aber nicht zu assi. Und die 89 dB(A) im Fahrzeugschein unter U1 sind finde ich relativ viel. Während der Fahrt macht er natürlich fast nix.
  • Das Getriebe (DQ381) schaltet (wenn es warm ist) meiner Meinung nach sehr smooth.
  • Der Platz im Kofferraum ist echt üppig. Ich glaube getoppt wird das nur vom Passat und Superb.
  • Assistenzsysteme (insb. der Travel Assist und der Totwinkelwarner) funktionieren sehr gut. Lediglich eine 360 Grad Kamera fehlt mir.
  • Das Infotainment ist sehr schnell, meiner Meinung nach schön und aufgeräumt und hatte noch nicht einen Ausfall. CarPlay verbindet sich wirklich sofort.
  • Die Verarbeitungsqualität (insb. im Innenraum) ist finde ich gut bzw. leicht besser als vergleichbare aktuelle Autos in der Preisrange (VW Golf, Skoda Octavia, Audi A3, Toyota Corolla). Es gibt fast kein Klavierlack und sie haben relativ viel mit Stoff oder Kunstleder überzogen. Lediglich auf der Rückbank und unterhalb des Sichtfeldes sieht man deutlich mehr Hartplastik. Und die Fächer in den Türen sind nicht mit Stoff bezogen, beim aktuellen VW Golf 8 (Facelift) sind sie es.
  • Der Sound aus der Sennheiser Anlage ist meiner Meinung nach sehr gut.
  • Kurvenfahrten machen mit dem Torque Splitter an der Hinterachse schon Spaß und auch der Drift Mode ist witzig.
Negativ:
  • Die Geräuschkulisse wird ab 130 km/h und höher deutlich hörbar. Golf-Klasse halt. Kein Vergleich mit dem Audi A6. Unter 130 km/h ist er meiner Meinung nach angenehm ruhig. Das Problem lässt sich aber relativ einfach mit lauterer Musik lösen.
  • Besagter Mangel mit den vibrierenden und summenden Türverkleidungen bei basslastiger Musik. Vielleicht kann die Werkstatt das aber beheben.
  • Kein dedizierter "Start/Stopp-Automatik aus"-Knopf und Klimabedienung nur via Touch. Da hätte ich gerne die Knöpfe aus dem Golf 7 Facelift.
  • Man muss aufpassen, in welche Werkstatt man geht. Eine wollte im Ernst für einen Ölwechsel 500 € brutto. Eine andere wiederum 180 € brutto. Beides Cupra Vertragswerkstätten.
  • Die Rückfahrtkamera ist bei Regen und Schnee sofort verdreckt (weil sie halt nicht in einem Logo versenkt wird). Man erkennt aber trotzdem noch, was passiert.
Verbrauch (2.0 TSI 333PS):
  • Kurzstrecke und Innenstadt (< 5km) ca. 9-10L/100km
  • Etwas längere Kurzstrecke (< 20km) ca. 8-9L/100km
  • Langstrecke (80 km/h) ca. 6L/100km
  • Langstrecke (100-130km/h) ca. 7-8 L/100km
danke für deinen umfangreichen Bericht. Bei den positiven Punkten kann ich zu 100% zustimmen. (y):love:
Die "Winterfelgen" sehen echt klasse aus. Viel besser wie auf den Bildern im Konfigrator. Das sind die Mistral, richtig?!
Ja genau, 19" Mistral Copper. Finde persönlich auch, das sind die schönsten Felgen von Cupra, schöner als meiner Sommerfelgen. Auch interessante Kombination, dass Winter schöner als Sommer, eigentlich ja eher andersherum 😁
Die gab es im letzten Winter als Winterkompletträder (Bestellnummer Z23-635-9V5-FN-PS4), aber im aktuellen Winter leider nicht mehr, ändern sie anscheinend jeden Winter. Ich hab meine neu von ebay bekommen.
Ich habe im November 2025 gekauft und da gab es sie nicht mehr als Komplettrad. Dafür habe ich auch ganz nette, nicht ganz so cool wie die Mistral aber ich bin zufrieden.
