Klinger1985
I have a problem with my Cupra Leon Sportstourer VZ 1.5 e-HYBRID (model year 2024): it either does not charge at all at public rapid charging stations or only charges up to a maximum of 22 kW (according to Cupra, it should be able to charge at up to 50 kW DC).
I usually use rapid charging stations with 150 kW output, and despite multiple attempts with different battery charge levels (battery at 0%, battery at 20%, or sometimes over 50%) and varying loads at the charging stations (sometimes only my vehicle is connected, sometimes two vehicles), I only get a maximum charging result of 22 kW. I have yet to see the 50 kW promised in the specifications...
For about two months now, there has been an additional issue where the charging process does not start at all. After about one minute, the vehicle aborts the charging process and unlocks the DC charging cable. The invoice always shows €0. The Cupra app reports to check the power supply or charging station... However, the problem is not with the different charging stations, as I have already ruled this out by simply waiting for the next customer, who was able to charge their own car at the same charging station without any issues.
Does anyone else have the same problem?
Morning,
for me exactly the same 1-to-1 as you described.
Mine goes to the dealer on 22.01, hoping for a solution,
we'll see, all the software at Cupra works according to the mood of the day.😔
The lower charging power is almost certainly due to the low battery temperature at this time of year.
Morning, well I haven’t quite reached the full 50 yet either, but 42 was my highest so far at an Ionity station. Otherwise, I haven’t had any problems with charging yet, and I hope it stays that way...
Low temperatures have an extreme impact on the charging curves. The 50 kW charging power is purely a laboratory value that can only be achieved under optimal conditions, so practically never in real life. Theory and practice, after all. Just as charging curves fluctuate and are never constant.
The same applies, by the way, to battery capacity/range, which also tends to weaken in cold conditions.
A few good pieces of information on this topic can also be found here: https://www.adac.de/rund-ums-fahrzeug/elektromobilitaet/laden/schnellladen-langstrecke-ladekurven/
Vielen Dank für eure Rückmeldungen zur Ladegeschwindigkeit.
Hat jemand bereits Erfahrung zu meiner zweiten Frage gemacht? Trotz einem weiteren Test an einer anderen Ladestation wird das Laden direkt nach einer Minute abgebrochen. Das Laden an DC startet einfach nicht?
Habe das gleiche Problem bei den Schnellladestationen mit 150 KW Leistung. Der Ladevorgang startet bei mir einfach nicht. Keine Ahnung warum. Maximales Ladeergebnis bei Shell Recharge lag bisher bei 21,862 kWh. Bin noch weiter am testen, aber DC laden hat noch nicht geklappt.
@Messerjocke bei einer Ladeleistung von 21,862kWh hat aber bei dir das DC laden geklappt...
Wie schnell du hier laden kannst hängt von dem Stand deiner Batterie ab (ab10% und höher lädt er auch schneller), die Temperatur und natürlich ob auch noch andere an der Säule zu der Zeit geladen haben. AC ist max 11kWh möglich, sprich bei 21,862kWh hast du also schon deutlich schneller als AC geladen, nur aber auch noch nicht ganz die hälfte von dem theoretisch möglichen 50kWh...
Liebe Grüße
@Ice-Mark Ich glaube du verwechselst da Kapazität mit Ladeleistung oder nicht? Bei meinen Ladevorgängen habe ich zum teil auch um die 21-22kWh geladen. Das Laden selbst hat auch mit 50kW bei mir problemlos funktioniert. Bei AC dürften also auch mehr als 11kWh reingehen nur halt mit maximal 11kW an Ladeleistung.
EWE Go sowie EnBW funktionieren bei mir beide einwandfrei.
@csxsi no, I clearly wrote that with a power of 21 kWh it can only be DC charging.
And as I wrote further, AC is only possible with a maximum power of 11 kWh....
I can't follow you here now, where did I mention anything about capacity with me? But all good!
A charging rate of up to 50KW DC is only possible under optimal laboratory conditions; usually, it will be around 20-30KW. AC achieves a maximum of only 11KW.
The battery has a capacity of 19.7KWh net or 25.8 KWh. Of course, at the current temperatures, it is significantly less. Additionally, there are usually several more consumers such as seat/steering wheel heating, etc.
@Ice-Mark die falsche Verwendung der Einheiten hat mich verwirrt. kW = SI-Einheit für Watt*1000 = Leistung. kWh=1000*Leistung in Watt*Zeit in Stunden = Energiemenge/Kapazität.. aber alles gut dann war es ja richtig gemeint ✌️
Wenn man sich mit dem Thema der Physik schonmal tiefer auseinandergesetzt hat liest sich das einfach anders.
Meiner will seit heute nicht mehr an der Schukosteckdose laden - es haut permanent eine Sicherung im Haus raus. Das Laden an einer Schnellladesäule schlug auch fehl; kann aber auch mein Fehler gewesen sein, da ich das noch nie zuvor gemacht habe. Sind gestern durch sintflutartigen Regen mit tiefen Pfützen gefahren. Vielleicht ist irgendwas im Motorraum nass geworden und verursacht einen Kurzschluß? Vielleicht ist auch das Ladekabel defekt, aber nach Einstecken zeigt es ein grünes Licht, bevor dann die Sicherung fliegt. Naja, diese Woche war ja noch nicht soviel los bez. Überraschungen, außer, dass er manchmal die Parkbremse unvermittelt an der Kreuzung reinhaut. :mad:
@fleckej es könnte aber auch vielleicht an deiner Hausverteiliung liegen oder? Je nachdem ist die Sicherung zu schwach, wenn in dem Stromkreis mehr als das Auto dran ist oder die Sicherung für die Dauerbelastung nicht ausgelegt ist?!
Nur ein Gedanke, nicht bös gemeint!
Habe über diese Steckdose fast täglich geladen. Auto schmeißt auch Sicherung von DC Ladestation beim Händler raus! Sind letzten Samstag durch schweres Gewitter gefahren mit tiefen Wassserpfützen. Könnte sein, dass dabei was verreckt ist.
Dann bleibt dir nur der Weg zum Freundlichen, wenn es überall passiert, würde ich dann auch eher dein Auto vermuten. Denke aber nicht, dass es normal ist, Auto wird halt auch mal nass, und ich denke mal, deine Pfützen waren jetzt nicht 1 Meter tief 😅 🙈
Ich hatte bis jetzt einen Ladeabbruch der auf Wasser zurückzuführen war. Kurz nachdem ich das Fahrzeug zuhause mit Hochdruckreiniger und Reinigungsutensilien bearbeitet habe.
Grund: Vermutlich die Flüssigkeit unter der Klappe des Ladestutzens. Ggf. mal checken und trockenlegen.
Am EnBW 150 kw Lader war die Anzeige Anfangs bei 51 KW. Ladedauer 26.5 Minuten von 8 auf 80 Prozent. Lade gerade bei Lidl am 50 KW Lader. Über 30 KW am Anfang ( 18 Prozent Rest im Akku) ging nichts. Jetzt bei 76 Prozent noch 22 KW Ladeleistung. Ladedauer auf 80 Prozent 28 Minuten.
Had the first time today the issue with not charging at the 150kW charger at Aldi. Same charging station I've used about 5-6 times before, even the same (fixed thick) cable. The charging process doesn't start, after about 1 minute an error is reported and the cable is unlocked. The charging station and the car don't seem to even "communicate" at all, which previously started immediately after plugging in. Temperature today was 2 degrees, and for the first time the battery was down to 0-1% (before always charged back up to 80% from around 10-20%). Then I charged with the 11kW AC cable, which worked straight away, but I stopped after 30 minutes and about 25%. I'll keep an eye on whether this happens again next time. With DC charging I've never managed more than 21-22kW, and the charging process to 80% took about 50 minutes.
