Cupra Models MJ25 & MJ26: Common Defects and Problems - An Overview
Welches MJ habt ihr und welche Probleme treten auf?
  • MJ 25 mit Ambientelicht-Flackern
    Votes: 12 33.3%
  • MJ 25 ohne Ambientelicht-Flackern
    Votes: 2 5.6%
  • MJ 26 mit Ambientelicht-Flackern
    Votes: 1 2.8%
  • MJ 26 ohne Ambientelicht-Flackern
    Votes: 1 2.8%
  • MJ 25 mit sonstigen Elektronik-Problemen
    Votes: 0 0.0%
  • MJ 26 mit sonstigen Elektronik-Problemen
    Votes: 1 2.8%
  • MJ 25 mit sonstigen Problemen außer Elektronik
    Votes: 4 11.1%
  • MJ 26 mit sonstigen Problemen außer Elektronik
    Votes: 1 2.8%
  • MJ 25 ohne Probleme nach Softwareupdate auf V. 2768
    Votes: 1 2.8%
  • MJ 25 mit Ambientelicht-Flackern UND sonstigen Elektronik-Problemen
    Votes: 3 8.3%
  • MJ 26 mit Ambientelicht-Flackern UND sonstigen Elektronik-Problemen
    Votes: 0 0.0%
  • MJ 25 ohne Ambientelicht-Flackern UND sonstigen Elektronik-Problemen
    Votes: 4 11.1%
  • MJ 26 ohne Ambientelicht-Flackern UND sonstigen Elektronik-Problemen
    Votes: 6 16.7%
  • Total voters
    36
Invio1
Forenfan ★★★
NATO
Hey guys. I'm wondering how much MJ 26 has experienced real improvements compared to MJ 25, whether it's the Leon, Formentor, or Terramar (pure electric vehicles aside, as the hardware and software are probably a bit different). Whether hardware, software, participate in the survey and feel free to also mention which vehicle you have and what problems occur, or do not occur.
If you have had problems disappear or arise after the latest update to version 2768 on your MJ25, please mention that as well. I'm curious to see what comes of this :).
EDIT: I just added the bottom four response options
So far, it appears that the ambient lighting issue has been resolved with the MJ26. Or we simply don’t have enough MJ26 drivers here, which I doubt. I can also well imagine that the new update 2768 can fix this problem and more, since to my knowledge the MJ26 vehicles are also delivered with this software version. I’m waiting for someone to say "MJ 25 without problems after software update to V. 2768" 😅.
I have MJ 25 and the software update since today. I will report back. :D
Currently, my eSIM is not functioning, but apparently not only for me, as the dealership updated several cars this week and they now have no eSIM function... Despite a complete update over two days of work.
Ja, bitte berichten! Ich habe jetzt doch für Ende November einen Termin wegen Update gemacht. Wenn jetzt aber die eSim allgemein nicht mehr funktionieren sollte und evtl. noch mehr neue Probleme auftreten, werde ich den Termin auf nächstes Jahr verlegen. Dann lieber Ambientelicht-Flackern. Sonstige Softwareprobleme habe ich nocht nicht bemerkt.
Da warten bestimmt mehr Cupra-Fahrer auf Berichte nach dem neuen Update.
Weiß nicht wirklich was ich auswählen soll :ROFLMAO:
Das Flackern hat nichts mit der "Hardware" also dem Modelljahr zu tun sondern mit der installierten Software:
Mein Formentor ist ein MJ25 und dazu noch ein ganz früher - produziert im Juli 2024. Einer der Facelift-Formentors, bei denen das Lichtband am Heck / die Rückleuchten bei deaktiviertem Abblendlicht noch NICHT geleuchtet hat o_O
Auslieferungssoftware des Infotainment war 2460. Damit hat über ein Jahr lang NIE etwas geflackert.
Im August diesen Jahres habe ich dann wegen häufiger werdender CarPlay Abbrüche das Aktulaisierungspaket "PV2+" bekommen inkl. Update des Infotainments auf 2565. Seit dem leuchtet das Lichtband am Heck, aber seit dem flackert auch die Ambientebeleuchtung sporadisch aber recht häufig.
Ich müsste also ZWEI Antworten auswählen:
[X] MJ 25 mit Ambientelicht-Flackern - seit Update auf Software 2565 im August
[X] MJ 25 ohne Ambientelicht-Flackern - mit der Auslieferungs-Software 2460 von Juli 2024 bis August 2025
Deiner Beschreibung nach ist der Punkt "MJ 25 mit Ambientelicht-Flackern" die richtige Wahl! Es geht ja um den aktuellen Stand. Im Endeffekt wird es wahrscheinlich wirklich rein an der Software liegen, weil MJ26 mit neuerer Softwareversion ausgeliefert wird und deswegen wohlm davon verschont bleibt. Bleibt nur die Meldungen abzuwarten, ob das Update von MJ26 auch beim MJ25 genauso wirkt.
Hatte auch eSIM Probleme nach dem Update. Der Cupra Support hat erwähnt, dass Sicherung 19 einmal für ca. 5 Minuten gezogen werden sollte. Habe ich gemacht und danach lief wieder alles. Wusste leider das Autohaus auch nicht.
Flackern ist seit dem neusten Update weg. Dafür die anderen Probleme nicht so wirklich.
Ich hatte in den ersten 1.000km (ca. 500km Dunkelheitsfahrten) mit MJ2026 / Software 2768 keinerlei Flacken beim Ambientelicht, obwohl ich sofort den Motor starte, ohne vorher die Zündung zu starten (also sofort Bremse & Start Engine).
Ich habe meine Stimme gerade angepasst von "MJ 25 mit Ambientelicht-Flackern" auf "MJ 25 ohne Probleme nach Softwareupdate auf V. 2768". Bin hier aber bestimmt nicht der Einzige, der das Update machen ließ und wo das Problem dann beseitigt wurde. Ihr könnt eure Stimmen gerne auch anpassen.
