Hello to all Terramar drivers.
I urgently need your help. I have a Terramar VZ Hybrid with first registration in 2026. I have a problem with my rear heating. There is simply no warm air coming out. The car has already been in the workshop several times. At first, nothing could be found, then it was supposedly a Bowden cable that had come loose, then a control motor was said to be broken. After all these repairs, warm air never came out despite various tests with the settings. During my last visit to the dealership, I spoke with the mechanic. He said warm air is coming out. He should show me. He inserted a thermometer with a probe about 10 cm long into the rear air outlet. Then he closed all the ventilation openings in the front, set the temperature (in the front area) to full load, as well as the blower. After that, some warm air came out in the back. The mechanic said that this is just due to the design and cannot be changed. But hey, that can't be right. So my question to you is: does warm air come out in the rear for you? Even if you set it to just 23 degrees or so? I would really appreciate your help.
