Diagnosis no longer possible, no communication (all control units)
DannyH83
One-Post-Wonder
Hello everyone,
My vehicle is a Cupra Formentor VZ 310PS, first registered: 12/2020.
Recently, my wife mentioned that a light illuminated in the instrument cluster while driving. However, it went out again, so I (an automotive master technician) wanted to read the vehicle using VCDS.
I connected the OBD plug, turned on the ignition... I noticed that VCDS can no longer establish communication with any control unit. It used to work; I have read the car with VCDS several times before. Communication is also not possible with other testers, not even for basic OBD diagnostics.
The car currently has no problems, no warning lights on, and everything is functioning. However, it can no longer be read!
I have already checked the power supplies and ground at the OBD connector = okay. There is also some activity on the data bus...
My suspicion is the gateway? (currently 5WA907530E installed)
Has anyone ever had such a problem or can help me?
Thank you very much in advance.
Best regards, Danny
