Display tire pressure
I believe there is no current display in BAR per tire here, as to my knowledge no active system is installed.
The control is carried out via the ABS system in conjunction with the speed and tire diameter of the respective wheel.
(Page 402)
What is displayed exactly in the infotainment under "Vehicle > Status > Tires"? Can someone please post a photo here?
The general information about tire pressure can be found on a sticker in the driver's door pillar, if that is what you meant.
(Page 392)
I actually meant whether there is a menu about the current pressure level of the individual tires.
Since there are no TPMS sensors in the tyres, this cannot be displayed either. If you want that, then you have to get something like Tiremoni.
Take a good tyre pressure gauge in hand and walk around the car once. I have had very good experiences, including with precision, using the analogue gauge from Flaig.
I use it for both my motorcycle and my car. I no longer trust the devices at the petrol station, having experienced differences of 1 bar there despite the calibration seal. They only measure when the tyres are cold, of course.
With systems that have TPMS sensors, you not only have the increased effort when the sensors reach a certain age and a tyre change is due, but there are also recurring problems with detection. We’ve just experienced this again with our Opel. The Ford was a bit more forgiving but didn’t indicate which wheel had the pressure loss, let alone the current tyre pressure. The Corsa can do it but regularly acts up.
I’m therefore glad to have a passive system without sensors again in the Cupra.
Ein einen guten Luftdruckprüfer in die Hand nehmen und einmal ums Auto rennen. Ich habe sehr gute Erfahrungen, auch was die Präzision angeht mit dem analogen Prüfer von Flaig gemacht.
Nutze ich fürs Motorrad wie fürs Auto. Den Geräte an der Tanke traue ich nicht mehr, nachdem ich dort trotz Eichsiegel schon Differenzen von 1 bar erlebt habe. Messen natürlich nur bei kalten Reifen.
Bei den Systemen mit RDKS-Sensor hast du nicht nur den erhöhten Aufwand, wenn die Dinger ein gewisses Alter erreicht haben und ein Reifenwechsel ansteht, auch bei der Erkennung gibt es immer wieder Probleme. Haben wir gerade erst wieder bei unserem Opel. Der Ford war dafür etwas genügsamer, hat aber auch nicht angezeigt, welches Rad nun den Druchverlust nun hatte, geschweige denn den aktuellen Luftdruck. Der Corsa kann's, muckt aber regelmäßig.
Ich bin daher froh beim Cupra wieder ein passives System ohne Sensoren zu haben.
Mega danke dir. Schaue ich mir im Detail an
Small addendum regarding the air pressure gauge!
By the way, I correct the pressure with the Bosch UniversalPump 18V. The manometer also displays very accurately, and with an adapter, you can even use the batteries from the blue Bosch Professional series or the AMPShare system, as in my case.
I have always charged the Bosch batteries in sufficient numbers as ProCore or GBA, the UniversalPump is also great to take along, and you don't have to bring the large 50-liter compressor up to operating pressure just to top off a few tires. It's faster this way than at the gas station.
Kann @JoergFB58 hier beipflichten, hab auch so viele P4A Akkus zuhause und mir dann diesen "Kompressor" geholt, sehr gute Anzeige, Lampe eingebaut und schnell vier Autoreifen auf SOLL gepumpt. Fahrrad geht natürlich auch.
Hatte vorher mal so ein Akku Teil von Xiaomi, das war der reinste Mist, selbst für 0,1 Bar nicht zu gebrauchen meiner Erfahrung nach.
Mit einem 4Ah Akku kommst mehrere Reifen/Fahrzeuge weit auch wenn du mal um 0,5 bar wg Urlaub o.ä. erhöhen musst. Der Bosch ist ausgesprochen genügsam, aber dafür mehr kräftig genug. Und wenn du sowieso im Akku-System, macht auch ein schlapper Akku mal nix. Schnell in die Werkstatt gesprungen und den vollen Ersatakku geholt. Das ist halt der Vorteil, wenn deine gesamte Werkzeuglandschaft auf einem Akkusystem fusst. Bei mir halt Bosch blau Prof., Grün DIY geht halt auch mit Adapter
