Fender flares Flaps
Cinobert
Hello everyone,
Has anyone here dared to tackle the topic of these flaps? In the new models, the entire tire must be covered by the wheel arch, or these additional flaps. I would like to put on wider spacers, but I would also need to install wider flaps. Has anyone found a solution for that?
If it fails with wider rims due to that one cm -> Adjust the camber for the approval and then revert it back. Or just the old-fashioned way and pull the fender.
I don't think the original stands out that much; however, it shouldn't be any wider.
I think I'll stick a few Temu things on for the inspection, which according to the examiner is fine, and then take them off afterwards. The original flaps don't stand out at all on my black paint.
That was the first thing I removed. After that came the lowering and registration according to §21. The fact that the flaps were removed didn't interest the inspector at all.
I tried it here with 3 examiners... all three said right away that the entire wheel should be covered at 30° and 50°.
That has to fit, but the wheel will end up rubbing against the edge of the fender or at the corners of the rear bumper anyway?
That's it, nothing is scraping. It's only 25mm lower and there's still plenty of space. I've already had it flexed with spacers at a friend's garage. I'll take a photo when I get the chance in the next few days.
Here you can somewhat see how the tyre extends over the flaps. Up to a certain model year, that wouldn't be a problem, but for mine, it concerns that not only the tread but the entire wheel must be covered.
During an inspection according to §21, the examiner should actually be able to apply the German variant as well; that at a certain height above the hub (I believe 15cm?) only the tread needs to be covered
The German version has also changed; since July 2025, the entire wheel must now be covered here as well. For older models, it can still be removed according to the version valid for the year of manufacture, as far as I know. Just like @Cinobert also wrote.
How did you remove the flaps? The rear is obviously screwed and glued, and the front is only glued, right?
They're not that easy to remove either 😃😃 Pull carefully, so you don't create a dent in the fender. The flaps are already sticking quite strongly.
