Formentor FL Grille
NS9556
Forenfan ★★★
Luxembourg
At least the Formentor has huge free air intakes in the grille. Stones with a diameter of 2 cm could fly through there unimpeded and destroy the radiator. Is there anyone here who knows a workshop that can install a coarse mesh racing grille in black behind the original? Another important question: if you do that, do you lose the factory warranty?
Japp, war hier auch schon Thema im Forum, ob das was an der Garantie macht, kann ich dir leider nicht sagen, nur dass mein Kühlergrill nun auch diverse Stellen zeigt, und das nach knapp über ein halbes Jahr.... 😭
Bin bei Cupra Saarbrücken im Gespräch, vielleicht geht da was
Dann halt uns hier mal gern auf dem Laufenden!!
auf jeden Fall, dafür ist ein Forum ja da!
Offizielle Cupra Werkstätten werden keine zusätzlichen Racinggitter einbauen da dies von Cupra nicht erwünscht ist und die Garantie verfällt. :(
so siehts wohl irgendwann aus ohne Racinggitter :eek:
It would have to be a clear warranty case, as the defect has apparently existed since delivery and there is also no intention to counteract it. To be on the safe side, I will also address my concerns to Cupra directly. If they confirm to me that they have no concerns, the email will be filed away in case of an issue. Because the only way to prevent this would be not to drive the car, which generally contradicts its purpose.
My newly ordered Leon (which is already at the dealer) has the same front.
The radar sensor is at the lowest possible position, but at least just as much of a lousy idea. It could have been implemented, presumably, much more protected above the license plate holder, two levels higher.
I would like to meet with the development department that came up with this and then approved it for a discussion....
Also, I was at a body shop today; it is almost impossible to properly secure a racing grille.
