Formentor VZ 4Drive in Midnight Black Metallic
Zero696
The pickup of my Formentor is approaching, and therefore I would like to introduce it here and then keep you updated over time.
It has become a Formentor VZ 4Drive in Midnight Black Metallic, which has also received the following special equipment:
- Intelligent Drive Package -> because I really wanted a 360-degree camera again
- Sennheiser "IMMERSIVE" sound system
The pickup is planned for next Saturday, and afterwards, the first pictures of the vehicle will follow. :cool:
Due to a lack of time and the current terrible weather, unfortunately, there are still no usable pictures of the vehicle.
I just wanted to show you two snapshots from the pickup a week ago, but since the pictures are too large for the Forum, you'll have to be a bit more patient. 😅
@Zero696
Just take screenshots of the photos and then upload the screenshots. That should work.
@Cupra-Klaus
Thanks for the Tipp, I have now simply reduced the images a bit directly in terms of resolution.
After it has been a bit quiet lately due to stress, here are the promised pictures from the vehicle pickup.
The first two small innovations have also made their way in. From the corporate sibling in the Czech Republic, there was a cap with a funnel for the windshield washer fluid.
Additionally, a rubber trunk mat from Azuga* was added to the car. Since I had these mats in my last two vehicles, the Formentor was now able to enjoy one as well. 😄
To get things rolling here soon, I recently visited the company I trust and ordered a few things for the Formentor. :cool:
My order included the following:
- peppered V2 coilover suspension including camber top mounts
- KW deactivation kit for the DCC
- a set of Sparco Assetto Gara Matt Black in 8.5x20 ET35
- Hankook Ventus Evo (K137) in 245/35 R20
The wheels should already be there, and now it's just a matter of waiting for the suspension for the Formentor to be delivered. :)
Unfortunately, there is still no news regarding the suspension, so nothing further has happened here. The only thing is the "cheese grater" from @Milan has meanwhile taken hold. :)
In 4 weeks, the car will first go to the detailer and will receive its ceramic coating there.
Actually, the Formentor was supposed to go to the detailer for ceramic coating last week, but unfortunately, the appointment had to be postponed to early October at short notice.
However, there was also some good news right away, as my upgraded suspension finally arrived last week.
Since earlier, the Formentor is now at Polybauer for installation and co., and I am really looking forward to Wednesday when I can pick up my car again.
8)
In the meantime, I'm once again out and about with this racer here:
If the sealing is also applied afterwards, then all my plans for 2026 will finally be implemented.
Great. (y) We have it in two colors. In black as you showed (our daughter drives it) and in white (my wife drives it). :D
Here’s a before picture of how the Formentor looks now with its 20" Sparco Assetto Gara and the spiced-up V2. :)
What is "peppered V2"??? By the way, the car looks like all the springs are broken.😩 What is broken there?
Isn't that even a kW V2, just a bit modified by "peppered"?
@dtmdriver
The gepfeffert V2 is technically based on the standard KW Variant 2 inox-line. The valve technology and the 16-way adjustable rebound stage are identical.
The difference lies in the construction: shortened damper housings and piston rods, as well as a modified spring system, allow for extreme lowering while maintaining sufficient remaining spring travel.
The suspension is manufactured directly by KW according to gepfeffert specifications, so it is not something that has been modified afterwards. Additionally, there is a separate parts certificate.
In short: KW V2 technology, but specifically developed for extreme depth.
@dtmdriver
The gepfeffert V2 is technically based on the standard KW Variant 2 inox-line. The valve technology and the 16-way adjustable rebound stage are identical. The difference lies in the construction: shortened damper housings and piston rods, as well as a modified spring system, allow for extreme lowering while maintaining sufficient remaining spring travel. The suspension is manufactured directly by KW according to gepfeffert specifications, so it is not something that has been retrofitted. There is also a separate parts certificate for it.
I couldn't have described it better myself. ;)
By the way, the car looks as if all the springs are broken.😩 What is broken there?
As you can see, nothing is broken at all. The car has just been modified a bit regarding my automotive fear of heights. 😄
As you can see, nothing is broken. The car was just modified a bit regarding my automotive acrophobia. 😄
Unfortunately, it just looks extremely modest. Low might be okay, but being so low that the wheels almost disappear behind the wheel arch edge has nothing to do with an appealing appearance.
