How often should the key battery be replaced?
das kommt bei Google raus:
  • Synchronisierung durch Zündung: Stecken Sie den Notschlüssel (aus dem Funkschlüssel entnommen) in das Schloss der Fahrertür und schließen Sie das Fahrzeug auf. Starten Sie den Motor innerhalb von 30 Sekunden.
  • Reset durch Tasten: Nach dem Wechseln der Batterie (Tipp: Vor Einsetzen der neuen Batterie die Öffnen- und Schließen-Taste für ca. 5 Sekunden gedrückt halten, um Restspannung zu entladen).
@Ice-Mark I have already tried the synchronisation procedure, which differs slightly from what Google described. One important thing is missing. The car key must be placed in the centre console near the 'keyless' detection point. Otherwise, the car cannot be started. In my case, I can start the engine, but the dashboard shows that the car key cannot be detected.
By the way, the car's alarm goes off. It feels like breaking into your own car.
I will try the reset procedure this evening. It wasn't clear to me which button(s) to use. I didn't read anything about it in the Manual*.
Update: unfortunately, the reset combination does not work.
I have already followed the Manual* procedure.
I had contacted the dealer. May be the car key has to be recoded. The key wasn't during service begin December where I also received the PV4 software update.
Begin March I have an appointment by the dealer. I will let you known what the outcome is.
--- Problem solved :love: ---
It turned out to be the battery after all. Today I happened to come across a box of CR2032 button cells in a completely sealed package. I gave it a try. When I inserted the button cell, I immediately saw the red LED light up. Then I tested it by opening and closing the car, which worked without any problems.
I still find it strange that the spare car key needed a more powerful battery.
interessante Beiträge.
Kann mir jemand sagen, ob beim Terramar angezeigt wird, dass die Batterie schwach ist? Ich habe bis jetzt einen Seat Ateca gefahren, da wurde es nicht angezeigt. Ich stand schon vor dem Auto und nichts ging mehr. Sehr ärgerlich, wenn es z.B. regnet und man dann an der Kappe fummeln darf, um mit dem Notschlüssel die Tür zu öffnen. Ich habe seit dem immer eine Ersatzbatterie im Handschuhfach, was aber für die Türe nix nutzt.
Gruß an alle.
Also ich kann zwar nur für den Leon sprechen, der zeigt es jedoch an.
Also ja, das Auto meldet sich rechtzeitig vorher.
Ab und zu gibt es auch bei frischer Batterie Probleme mit dem Kessy, aber nichts tragisches.
denke, bei allen Cupra´s wird "Schlüsselbatterie wechseln" im display angezeigt. Wüßte nicht, dass hier jemand schon einmal von Gegenteil berichtet hat.
Die Anzeige erscheint für ein paar Tage bei jedem Start, dann wird´s aber Zeit, eine neue einzusetzen.
Nicht vergessen: alte Batterie raus - Taste am Funkschlüssel drücken (reset) - neue Batterie rein.
Super, danke.
Dann ist das ja schon mal ein Fortschritt, gegenüber dem Ateca.
It's now time for me after about 1 1/4 years. The display shows the battery needs to be replaced in the key.
My key is still using the original battery after 1 year and 9 months. The spare key, which has been stored in a shielded case and was briefly used last week, immediately indicated that the battery needs to be replaced
I meant the Panasonic was installed from the factory; they typically last the longest.
Edit: I just saw the Amazon link. One always has to be careful; even if they are the right batteries, if you choose particularly cheap offers, you might end up with batteries that have been stored for years, which ultimately do not last any longer than the cheap Ikea batteries.
I had that problem recently. I had to replace my battery and happened to have some that I ordered from Amazon earlier this year for something else. I put them in and nothing happened (the red blinking light was blinking). At first, I thought the key needed to be programmed. That didn't work. I then put the old one back in and it worked with that. I only buy batteries from a store now. You can also get them at Rewe, Globus, a hardware store, or similar places.
First battery replacement after about 3/4 year.
PS: What or how cheaply do you order there 🫣? The batteries have a kind of expiration date printed on them, until which they should be usable. With my orders through Amazon, I easily have another 8-10 years left. (usually Varta)
Yes, but a 10-year-old battery just doesn't last as long as a 2-3 year old one. Hardly anyone looks at the date; most buy based on price, and with the really cheap ones, it's usually only a few years until the expiration date. And then a Varta is on the same level as Ikea. If you have batteries with an expiration date of 2034-36, that's fine. 😉👍
And then a Varta is on the level of Ikea.
Attention irony: so over time, the Varta gets better?
No joke: Varta cells have long been the last rubbish, whether consumer batteries or as starters. No wonder they are bankrupt.
My key is starting to behave strangely after 1.5 years. Kessy works perfectly both in the car (ignition) and outside (locking/unlocking). However, the key buttons are now very unreliable (sometimes it works (even from a distance), sometimes it doesn't). I just had to open it via the lock (including alarm ...) because I had turned off keyless. The LED on the key also no longer blinks. Neither when I press a button nor when the key is near the vehicle. However, my Cupra does not show any warning that I should change the battery. Everything seems inconsistent somehow.
Oh. I know that by now too. Everything where you have to press the buttons for a long time, like comfort opening of the windows, boot lid, only works every now and then. Simple unlocking works, though. KESSY also feels like it has deteriorated. Last battery change was about 3 weeks ago, didn't help. I'm in the workshop next week anyway, so I'll bring it up then...
