Ignition off, lights off inside/outside
Fritz_Müller
How annoying is that? You've reached your destination, turned off the ignition, but the car just won't turn off the interior lights, and the parking lights won't turn off either. How can you turn off all the lights inside and outside the car while sitting inside with the ignition off? Just like before 😅
Du musst nur lange genug warten. Dann gehen die Lichter aus, innen und außen.
@Fritz_Müller Press the mode button on the light control (to the left of the steering wheel towards the footwell) until nothing lights up = no exterior lights. Press this "button" on the roof console so that it lights up = no interior lights - this also means that the lighting will not turn on when a door is opened or when the ignition is turned off. (this setting remains in effect)
@Fritz_Müller nach dem Zündung ausschalten einfach kurz die Tür öffnen und wieder schließen, dann geht es schneller aus. Mach ich auch immer wenn ich im Auto auf meine Frau warten muss😉
