- Interior lenses unevenly bright
Welcome! You have been invited by Gand-Alf to join our community. Please click here to register.
SaschaForum
Hello everyone,
what I noticed recently is that with my HD-Matrix headlights, the 2 inner lenses are of different brightness. When standing in front of them, it looks like one inner lens is not lit while the other is "normally" bright. Only when you kneel down can you see that the other lens is on, but significantly dimmer?
At first glance, it visually appears as if one is broken. It also looks somewhat strange...
And do you also always have to manually activate the Matrix when starting off? With my wife's K2, the "A" for the Matrix is always on automatically.
Is it the same for you?
Best regards,
Sascha
Ggf werden die nur für die Projektionen auf der Fahrbahn dazu geschaltet?
Gehen die zB bei der "Welcome Ceremony" mit an?
Dass die Fernlicht Automatik beim Start aus ist, dürfte normal sein.
Frage in eigener Sache? Fährt man sonst nicht auch mit Fernlicht durchs Wohngebiet? :unsure: 😅
Are they possibly activated only for the projections on the road?
Do they, for example, also turn on during the "Welcome Ceremony"?
That the high beam automatic is off at startup should be normal.
Question on my own behalf? Don't you usually drive with high beams through residential areas? :unsure: 😅
- During the Welcome C... both do NOT turn on.
- In my wife's K2, it's set to on by default, as "A (Auto)"
- No, the matrix automatically turns off when entering the town
Do the lenses on the right and left have two different functions?
EDIT: I just took another close look.
- The left lens is slightly oval and the right one is round
- With normal low beam, the (viewed from the front) left one is bright and seems to shine far, while the right one is relatively dark and shines more downward
- With manually activated high beams, both lenses are bright
It really seems that each lens has its own function and does not act synchronously. It still looks strange from the front 🙈 and gives the impression that something is broken 😅
Nein, Matrix LED ist innerhalb geschlossener Ortschaften deaktiviert ( Deshalb ist es ja auch die Automatik :D ) Das scheint er über die Kartendienste zu erkennen.
Dass die immer aktiviert werden muss, statt sich den letzten Status zu merken, ist bei Cupra leider so.
Mein Matrix leuchtet auch innerorts, solange es dunkel genug ist, erkennbar an den Orientierungsbalken, die es auch deutlich unter 50km/h noch zeigt, nur kürzer.
Die Welcomeprojektion mit dem Cupra-Schriftzug macht die linke Projektionseinheit.
HD-Matrix Scheinwerfer die 2 inneren Linsen unterschiedlich hell sind
ist das nicht der Sinn vom Matrix ?
Ob die Linsen rechts und links zwei unterschiedliche Aufgaben haben?
beim Matrix m.W. ja. Der Lichtkegel des linken Scheinwerfers spart m.W. den entgegenkommenden Verkehr aus.
linke Linse ist leicht Oval und die rechte ist rund
aus o.g. Grund würde ich meinen.
Aber unser vFL hat kein Matrix. Meine, es nebenan so mitgelesen zu haben und hier aus der Erinnerung hoffentlich richtig wiederzugeben.
Deshalb nehme ich an, dass das Matrix genau das tut, was es soll, nämlich gewisse Bereiche abdunkeln, wenn Du davor kniest.
Ich meine, Ortschaften etc. erkennt er nicht anhand vom Kartenmaterial, sondern an äußeren Lichtquellen. Wenn es hell genug ist, schaltet die Automatik das Fernlicht aus. War auch bei meinem Ford Focus so.
Da die Betriebsanleitung* keine Bildbeschreibung zu den Lichtern hat und ich das schwache Licht gestern Nacht auch entdeckt habe, frage ich hier nach ob es sich um das von mir rot markierte Licht handelt?
Ja, das sind die matrix-projektoren links und rechts.
Danke!
Nun frage ich mich, wie der Fahrer auf meinem Bild das Licht so stark zum Leuchten gebracht hat? Ich habe gestern im dunkeln alle möglichen Kombinationen versucht und entweder hat dieses Licht gar nicht geleuchtet (das andere schon) oder weitaus schwächer als das andere.
Das sind nur die Projektoren. Vielleicht war der auf dem Bild in irgendeinem Testumfeld.
