Known TPI (Technical Product Information)
Melfinos
Lebt hier ★
European-Union
Here, a collection of known TPIs is to be created.
Therefore, the request to all of you for support in sharing your information in this thread.
(y) ;)
At the ROC, there are brake pads, some batches of which "moo". The term is actually known as such at VW.
Before making a complaint, it is best to record a video showing the number plate clearly.
The pads will be replaced.
Since it did actually happen that "mooing" pads were installed a second time during the replacement, the corresponding TPI has been revised.
The currently valid TPI has the number: 2049996/10. The part number of the correct pads must end with a "J".
Maybe this helps you.
TPI Code 2075376/2
Inhalt: ???
TPI Code 2075376/2 Inhalt ???
TPI 2076933/2
Maßnahme:
TPI 2070059/3
Maßnahme:
I have a 1.5 eHybrid (272HP)
I received the following information about my VIN in ERWIN.
5x high voltage / charging technology
1x CarPlay
Edit by @stefanerWin manuals removed due to copyright infringement. Please take note in the future. Thank you :)
TIS, to refill the silicate in the coolant reservoir
do I understand correctly that this concerns the coolant itself, which can potentially lead to flocculation in the cooling circuit, manifesting as silicate flakes /-clumps /-sludge in the expansion tank?
The problem has been known at VW for years, and if there is now a TPI for it, all the better.
The "old" coolant G13 (written on the expansion tank) is organic, more environmentally friendly, and cheaper to produce. Unfortunately, it has the property of dissolving the coating of the coolant hoses, leading to deposits in the expansion tank.
The "new" coolant G12 EVO (also written on the expansion tank) is mineral-based and does not dissolve the coating, so no flocculation occurs.
In 2020, a ROCer writes that "everything will be replaced under warranty (heat exchanger, expansion tank, coolant)." Which of the two coolants will be refilled afterwards is decided by VW. Hence the note "written on the expansion tank."
I suspect that "silicate" is likely sodium silicate, which is mineral-based and can also be used as antifreeze (or as a binder in paints and plasters or as a weed killer in joint sand). It is highly caustic when undiluted, with a pH around 11...
I'm really looking forward to my service, let's see what gets fiddled with again and what errors will have been fixed by then...
@Gand-Alf
Thanks for the info. I was not aware of the precipitation issues in connection with the G13 coolant until now.
Maybe a small addition. Our ROC also has G13 filled in, at least according to the label on the expansion tank. So far, it hasn’t had any flocculation after a total of six services.
Therefore, it is suspected that the G13 might only dissolve certain radiator hoses, a specific batch, certain model years, or engine types. The colleague mentioned above had a 2.0 TSI at the time. Perhaps different hoses are fitted there. By the way, he had G13 refilled again :oops:
Da ich genug andere Dinge hatte, die gemacht werden sollten, habe ich nicht nachgefragt.
Denke aber das in den Ausgleichsbehälter einfach dieser Silikatbehälter neu befüllt oder vielleicht erst eingesetzt wurde 🙈. Oder entfernt, weil es Probleme gab 🤷‍♂️
