Hello everyone,
I wanted to share my issues with my Cupra Leon 1.5 eTSI (07/2023, 35,000 km, warranty extended by me by 2 years) with you, as it seems to be getting increasingly complicated. Maybe this sounds familiar to some of you, and you could give me a few pointers on what else I could try.
I bought the vehicle from a used car dealer (not a Cupra dealer) with around 5,000 km on the clock (9 months old). After a short time, I noticed that whenever I drove over cobblestones or uneven surfaces with the window open, there was always a metallic clicking sound coming from the front left. After two days of inspection, my Cupra workshop concluded: gearbox defective.
Klappergeräusch vorne Links
Okayyyyy, that went pretty quick... The gearbox was replaced under warranty, and I drove off the lot, over the first bumps... Well, I don't know what to say, the noise was still there... I drove it for another 8–10 weeks, then it started jerking during driving and shifting, etc.
The workshop looked at the problem again and said it was coming from the gearbox once more... Bang, another gearbox replacement. Installation error? We don't know.
When I drove off the lot again after four days, the noise was naturally still audible. I thought, well, as long as the car drives properly, it can't be anything serious. I don't really care about the noise...
Some time passed, and the driving behaviour became increasingly odd—it no longer felt "right." The car drove uneasily, jerking during acceleration.
I don't know how to describe it, so I'll try explaining it using layman's terms.
The original knocking noise when driving over uneven surfaces is still present. Occasionally, it still jerks while driving
The Cupra drives completely normally. I park the car. When I want to drive off again after some time, the Cupra feels totally different and starts jerking. I also noticed that the accelerator pedal feels different—somehow it's no longer as "sensitive," or the Cupra doesn't respond to the throttle as precisely. You give it a little gas, but somehow the car suddenly takes away the thrust, then automatically gives more thrust, causing jerking. Or you press the pedal slightly, and the response only comes after a perceived 1–2 seconds. As I said, sometimes it drives completely normally. You immediately notice whether the car is driving "normally" or whether something is off again.
It feels totally strange when I drive over a bump and immediately give a little gas—the Cupra jerks sharply forward with higher revs, as if something inside was shaken loose by the bump and isn't working properly for a moment. Even if, for example, I keep my foot lightly on the accelerator in a 30 km/h zone to maintain 30 km/h, the car suddenly and briefly takes away a tiny bit of throttle (feels like a "vacuum hole") and then pushes forward again with slightly higher acceleration. At that moment, the accelerator pedal also feels overly sensitive.
After describing this to the workshop (this time the advisor was already slightly annoyed), they replaced the throttle body and the engine mount, and updated the engine control unit.
After that, I drove off the lot and had extremely loud creaking noises. I immediately showed it to the advisor again, who said it might have been installed slightly crooked during the engine mount replacement. He lubricated something and scheduled a follow-up appointment in two weeks.
Knarzgeräusch
Within the 2 weeks, the noise disappeared, and the workshop did not carry out any repairs in response. The car drove reasonably okay after the repair, incidentally. Now, another 8 weeks have passed, and driving the car is no longer enjoyable again. It's exactly the same issues as before...
Now I'm wondering what this could be?
Could it be the accelerator pedal? Misfiring? Suspension? Again, the gearbox? Control unit?
I'd appreciate any responses
Knarzgeräusch
