Leon St VZ 333hp Blow-off Valve
Aimstar187
Good evening everyone,
I've searched endlessly on Google but unfortunately didn't find anything. Maybe you are my salvation.
I drive a Leon ST VZ from 2026 with the DNFF. I'm desperately looking for the blow-off valve. It's not directly at the front of the turbo next to the inlet. Maybe someone has a Tipp 😅
No, unfortunately, it's not located there, like in the GTI or similar models.
It's in front of the engine, about in the middle of the vehicle, but behind the engine fan. Approximately 50cm deep.
If you want to change that part, you can probably reach it with thin arms and small hands by removing the underbody from below.
Otherwise, the fan has to come out, and even then, it's a real hassle.
If you trace the thin hose that goes into the intake before the turbo, you can get an idea of where that part is.
I abandoned the plan to replace that part after watching the video 🤪
Installationsvideo
@dtmdriver Does that fit? Then that would certainly be helpful for orientation.
Wow, thank you so much. We have searched high and low for one and were really getting desperate. I'll check right away.
@ekm
I think that should work, but it looks way too simple without all the other components :LOL:
Reactions: ekm
