Navi outdated. Is that okay?
eislecke
Hello everyone,
I just checked my system information and believe that at least the navigation is outdated. The 22.6 means that the material is from mid-2022, right?
Could someone possibly take a look and tell me if that’s correct? The vehicle is 1 year old. How can there be maps from 2022 on it? o.O
Can someone take a look at this for me
hello, here you can "update- news" to read up on Navi- DB, apps, etc. The latest posts are from September. Navi- DB 25.8 seems to be current.
For the update of the software and navigation database, it also depends on how you update, "over the air" (OTA) so automatically (as far as I know, this is chargeable > in other words, contract), via download from the Cupra server to a stick for the navigation (from what I can gather from your posts, you have already dealt with @Milan entertain > free, so you have to be active yourself), via app (as far as I know, it’s paid > meaning contract).
just theoretically:
Yours is first registered 07/24. What is the MY (model year), what is the BJ (year of manufacture)? Therefore maybe the DB from 22, which has not yet been updated via one of the above-mentioned ways.
Yours is a year-old car. Where was the previous owner driving? I ask because the OTA update, to my knowledge, is only automatically updated in the "honeycomb" of the map material where the car predominantly moves. Is the "connect" contract still current?
In some areas, the OTA reception is not optimal. Or the time to transfer updates OTA is too short > "short distance"
nur rein theoretisch:
Deiner ist EZ 07/24. Welches BJ (Baujahr), welches MJ (Modelljahr) ? Daher vlt. die DB von 22, die noch nicht auf einem der o.g. Wege aktualisiert wurde.
Deiner ist ein Jahreswagen. Wo war der Vorbesitzer unterwegs ? Frage deshalb, weil das OTA update m.W. nur in der "Wabe" des Kartenmaterials autom. aktualisiert wird, in der sich das Auto überwiegend bewegt. Ist der "connect" Vertrag noch aktuell ?
In einigen Gebieten ist der Empfang OTA nicht optimal. Oder die Zeit, updates OTA zu übertragen, ist zu kurz > "Kurzstrecke"
Vielen Dank für deine Antwort.
Komme leider jetzt erst dazu, dir zu antworten. :-(
Die aktuellen Navi Daten (10/2024) habe ich mir mal runtergelden.
Mal schauen, wann ich das installiere, denn das soll ja ne Weile dauern.
Also welches Modelljahr mein Leon hat, weiß ich leider nicht.
Kann man das herausfinden?
Connect Dienste sind seit 08.05.2025 abgelaufen, habe ich heute in der App gesehen.
Habe heute auch erst gesehen, dass ich gar nicht als HAuptbenutzer angemeldet war und habe das mal nachgeholt.
Ich dachte immer, dass die Connect Dienste 10 Jahre kostenfrei dabei sind beim Fahrzeug.
Irgendwie blicke ich da immer noch nciht richtig durch bei den ganzen Dingen wie Connect Dienst, Cupra Care und das alles.
Finde ich maximal verwirrend, dass man nicht irgendwo zentral sehen kann, welche Dienste da alles gebucht sind und welche nicht. 😅
ja, z.B. anhand der FIN (dt.: Fahrzeugident.-Nr.) oder VIN (engl.: Vehicle identnr.). An der 10. Stelle der FIN steht der Modelljahrescode. Der code folgt bei VW einer gewissen Systematik, im web zu finden.
oder anhand Deiner Kaufunterlagen bzw. der Betriebsanleitung*, die für MJ (nicht Baujahre) geschrieben sind.
bzw., falls Du weißt, wann er gebaut wurde TT MM JJJJ - der Modelljahreswechsel erfolgt grob im Sommer. Ich hatte mir mal gemerkt "nach den Betriebsferien im Sommer", habe aber auch schon irgendwo ein fixes Datum gelesen, kann sein, dass das hier im Forum war.
Bei dem äpp- Gedöns kenne ich mich leider nicht aus. "Cupra Care" ist ein service- Angebot (Vertrag).
zum "Durchblick" kann ich Dir aus Erfahrung nur raten, fleißig im Forum mitzulesen oder einfach mal in der Suche nach diesem und jenem zu suchen.
Vielen Dank für die sehr lehrreichen Infos.
Modelljahr ist R=2024
Hab auch noch im COC nachgeschaut und da steht
"Date of manufacture of the vehicle 26.03.2024"
Sollte so fast mit einer der letzten der VFL Modelle sein.
Vielen Dank nochmals. :) 🍻
