Navigation crashed. Displays incorrect position.
Mesche900
Hello everyone,
since this morning my navigation system has been showing an incorrect position. As a result, the Travel Assist no longer works. I have restarted the infotainment system several times (long press on the power button), but without success. The app also shows the car’s position incorrectly.
Has anyone else experienced this, or does anyone know what else might help besides waiting for an appointment at the dealer?
Best regards
Micha
I know this from both the pre-facelift and the facelift, I've had it quite often.
Park the vehicle and lock it, wait 15 minutes, and then try again. For me, this has always solved the problem.
In my pre-facelift Leon, the head unit was replaced back then, after which I had the problem less frequently; in my facelift, it is currently occurring more often again.
Apparently, Cupra also installs old head units in the facelift (you can tell by the locking mechanism of the SOS button).
Here's a video of how it looks for me:
@y8nn8ck that's crazy that the sat nav is so faulty.
I haven't experienced anything like that with my vehicle sat navs for 10 years (not VAG or a German group).
Unbelievable... no wonder vehicles from German groups are being sold less and less.
I've often wondered about the problems mentioned here in the Forum why I chose a manufacturer from a German group.
But there are many registered vehicles and comparatively few reported problems 😉
That's my hope, that in the end I made the right decision.
As they say, hope dies last 😉
I had this exactly once with my facelift a few weeks ago. It couldn’t find the exact position and was somewhere in the middle of nowhere. The traffic sign recognition was acting up because of that, etc. It happened again when I had started the car too quickly.
After switching it off for 5 minutes, everything was fine again.
Has anyone else had this, or does anyone know what else might help
hello,
yes, there is a thread "Navi loses location" from 2023 "next door".
According to the navigation system, someone is driving off-road and sideways, which also affects the ACC.
The following solutions have been suggested:
  • Is the navigation software up to date? Which bundle?
  • Pull the central electronics fuse; the GPS antenna will be recalibrated
  • Disconnect the battery so that the control unit is without power and recalibrate the navigation system after reconnecting
until someone says the error is known and the control unit needs to be replaced.
Another user corresponded with VW and posted the following response from VW:
The map data is divided into fixed regions. Updates are only made for map regions where you regularly travel.
The map update is automatically downloaded when
- the vehicle’s GPS position is within a 50 km radius around the new map region, or
- a new update is available for the "home regions".
For this, the vehicle automatically "asks" the backend during every online connection whether there is a new update.
Up to 12 updates are made available online per year.
The updates now run automatically in the background as soon as the vehicle reaches bus rest mode and are no longer manually triggered. However, the update is not immediately visible in the infotainment system’s maps because it must first be installed.
Hallo Zusammen!
Hab das Problem mittlerweile gelöst. Ich hab das Mediasystem neu gestartet. Es hat nur deshalb nicht gleich funktioniert, weil ich im Parkhaus stand. (Ich weiß, hätte ich selbst drauf kommen können :)). Jetzt gehts auf jeden Fall wieder. Der Händler hat mir noch den Tipp gegeben, auf Werkseinstellungen zurückzusetzen und dann mit dem Hauptnutzer wieder anzumelden. Das hat wohl bei einem Vorführer von denen geholfen.
Ich hatte das in meinen 10 Monaten genau einmal, ausgerechnet einer der letzten Tage...
Die Stadt stimmte zwar aber Position um ein paar km falsch.. die Anzeige versuchte damit klar zu kommen, fuhr dann aber durch Gebäude und Niemandsland.
An der Ampel stand es auch nicht still, hatte aber nicht das Gefühl, dass sich die Anzeige irgendwann meiner Position annähern würde, die Himmelsrichtung stimmte aber schon.
War dann recht kurz beim Arzt drin und als ich zurück kam (vermutlich knapp/unter 15 min) und hatte auf der Rückfahrt das Problem noch immer.
An nächsten Tag war dann alles wieder ok.
What on earth is bus silence???? But if my navigation worked "that" way, I would switch to Waze and that would be that. Unfortunately, I'm not the kind of person who likes to deal with non-functioning things and would probably end up "eventually" annoying someone in the workshop.
whether the CAN bus (Controller Area Network) is currently idle when no update is being installed, I do not know. According to a response from VW, it is at least only under o.g. Bedingungen "addressed" (active).
