Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Older software version than after the PV4 update, but you haven’t missed anything. The main thing is that the car has no problems!Hi. Yes, only an update to the parking assist control unit was installed. No other updates were applied.
I specifically asked about PV4 and was told that it is only done if certain errors occur, for example: flickering interior lighting (Leon) or illuminated airbag/engine warning lights.
Also depending on entries in the fault memory.
None of that applied to me, so only the TPI was done.
My infotainment still shows version 2650.
Do you mean that you haven’t received the message for 5 days without having installed an update or done anything else for it? Otherwise, your sentence doesn’t make sense, Google translator or not.I have been quiet for 5 days, I haven’t done anything.
Hi, ich habs im Januar machen lassen und keine Probleme damit. Die Meldung kam seit dem auch nicht mehr.An diejenigen, die das Update für das Steuergerät der Einparkhilfe gemacht haben, um die Meldung "Neue Einstellungen sind jetzt für Ihr Benutzerkonto verfügbar" wegzukriegen (TPI 2078860/*):
Habt ihr seitdem neue Probleme bemerkt, oder scheint das Update stabil zu sein?
I had also asked to stay on 2768.@Timmm987 What software number does the system have after the update to PV5? PV4 was 2768.
No, the car is going to the workshop on Monday for 2 days, I'm very curious and will give you feedback.@Timm987 : Has the PV5 been installed on your vehicle yet, and if so - have you experienced any (negative) "side effects"? I have an appointment for the first oil change soon and have also requested to carry out the TPI... but if there is a complete update (PV5) and this doesn't cause any issues with new errors, installing the PV5 might be the better option.
