Opening and Closing Glass Roof
Uli 1008
Hello, the comfort opening and closing should also operate the glass roof, but it doesn't work on my Terramar. I have to control it using the controls on the roof. I'm sure it has worked before. Is there a trick that I might have overlooked??? Maybe someone has a hint? Thanks and regards, Uli
Hold the "Up" button on the key for a reaaaaaaaally looooooong time, then it should actually open.
Reactions: ekm
Information from the dealer: the calibration of the side windows has been lost, which is why opening/closing via remote control does not work; after recalibration, it works again, including the glass roof 🤗
Brave new world. :D
Good, that can be done quickly by yourself.
Simply drive the windows to the end position and then hold the switch pressed for a few seconds. The window will then move once amusingly from top to bottom and back. Then the endpoints are recalibrated.
Mine had the same issue at delivery. Did it once and since then everything has worked perfectly.
But interesting that the roof is connected to that.
But the comfort opening is activated in the infotainment, right? If it is still deactivated, it won't work with the key either.😉
Hatte ich letztens auch erst. Musste beide hinteren Fenster resetten. Bei mir tat sich mit Komfortöffnen gar nichts. Weder Fenster, noch Dach.
So weit ich weiß ist es so, dass selbst wenn nur eine der Scheiben nicht mehr kalibriert ist, dann alle Scheiben nicht mehr auf die Komfortöffnen-Funktion reagieren.
