Power window on the driver's side has problems closing.
This "feature" with the window lifter is also present in my car. But I don't care; if that's how it is, then I'll just lower the window all the way down and back up again, that won't break my crown. If I don't have any (self-imagined) "problems" with the vehicle, I am very satisfied and can consider myself a happy person.
That's true, but my dealer is 25 km away and I've been there more often than I'd like.
This "feature" with the window lifters is also present in my car. But I don't care; if that's how it is, then I'll just roll the window all the way down and back up again, it won't break my crown. If I don't have any (self-imagined) "problems" with the vehicle, I'm very satisfied and can consider myself a happy person.
I fundamentally agree with you. The car itself is very nice. But with a purchase price of nearly €40,000 and no leasing, I do expect these things to work. It is quite annoying during highway drives, in rain, snow, etc., when the windows open completely. However, I do hope that the dealer/manufacturer can get this under control.
So, a quick update:
today the window regulator on the driver's side acted up again after working fine for a long time.
I have a vague suspicion now. I have been riding my motorcycle for the last few days and the car has been sitting in the garage. After I drove the car today, I went to the vehicle and the automatic unlocking of the car didn't work
I would first rule that out; I recently had problems with the driver's side for the first time as well. I took mine in for its first inspection this week and mentioned that to them. They reconfigured and adjusted the driver's side. Let's see if I have another problem with it. However, I had never had any issues before, but I also rarely operated the windows, so don't take me as a reference...
@ac-san
If the car couldn't be unlocked after a longer period of inactivity, I would suspect a general under-voltage issue with the 12V battery. That wouldn't be anything new.
Unlocking worked already, but not through proximity.
However, I believe I have found in the Manual* that after a longer period of inactivity, unlocking only works with the key and not keyless.
That may be. However, that does not explain the window regulator issue.
When I open the window on the driver's side about 1/3 to let some air in and then want to close it (after about 1-1.5 minutes), it tries to open all the way. If I stop it and try to close it again, it continues to open. Once it is fully open, it can be closed again.
I only read your first post on page 1 of this topic, so I'm not fully up to speed.
Could it be that the automatic follow-up when opening/closing, which is probably called "Comfort Opening/Closing" in the MIB, is activated and that only partially (1/3) opening the window just grazes the point where the comfort opening starts to work, causing the door control unit to "choke"? In that case, maybe try to... Fensterheber neu anzulernenThe switch-on point for the after-run may no longer be precisely defined in the control unit.
Bold theory, but a possibility if this hasn't already been mentioned.
A defective control unit (this can happen quickly, I speak from experience) would be the next possibility, but only if the learning process yields no results.
I can't explain any of this either. The passenger side window regulator was replaced in my car and has been working since then. The driver side was not available. After over 1000 km of driving in one day and a week later the same amount back, the driver side window regulator worked without problems for at least two weeks, and the Start/Stop function suddenly worked as well. Now I'm having the same problems as before the vacation regarding the windows and S/S. Maybe it's also related to the battery somehow, but certainly not only because the automatic unlocking works continuously without issues.
At the end of October, the window regulator on the driver side will be replaced. It's currently frightening how it behaves; the window always goes in the opposite direction than I want, and I have to hold the button completely down.
@Gand-AlfI have already tried re-learning it several times. It has partially worked. But the problem is that it only works intermittently / does not work. It's a bit like playing the lottery. :) According to my service guy, everything that can be replaced in the window has been replaced. By now, I have decided to leave it as it is and wait for PV5. No idea if it will help. The last 2 days have been quiet again and it has worked.
In the meantime, the window regulator on the driver's side has been replaced and is working normally again. However, the good guys at the workshop apparently forgot to reconnect a plug, because now the door sensor for opening/closing is not functioning anymore. It works on the passenger side. So, back to the workshop again. Frustrating....
You're right.
But what can I say? On Friday evening, I passed by a smoking car.
After I opened all 4 windows to air it out briefly and then closed them again, all 3 repaired window regulators had the same problem again.
It's frustrating...
That's basically correct, you can easily make the basic setting yourself. 1. Manually lower the window to the first notch from the switch, briefly release it, and then press the switch all the way down for 3 seconds. 2. Do the same for raising it, then the error should no longer occur.
For those whose window regulators have been repaired: Were your repairs successful or did the problem come back?
Has anyone here found a concrete solution to the problem? My vehicle just came out of production in September and I have the same issue. The workshop says it's a component fault and they can't do anything about it right now?!? The problem has apparently been known for ages; I can't understand how such a "simple error" can't be fixed over such a long time...
It's a shame to hear that. I don't understand it either. It affects 3 window regulators for me, 1 is working. And I've been running around with this since January.
Let's see, on Monday it's going to the workshop..nothing will be done anyway but oh well..they already said on the phone that nothing can be done at the moment 😁
