Hello everyone!
I recently got the Cupra Leon SP Estate ETSI 1.5L and I'm really excited!
However, I've noticed that the high beam doesn't work.
Whether it's automatic, Manual* high beam, or flash-to-pass, the low beam just gets brighter but I still can't see anything...
I googled and found several videos on YouTube: Full LED Headlight Test from Cupra Formentor/Leon and Seat Leon. They are supposed to have the same ones as standard.
In the videos, I see how the high beam is activated, the low beam gets brighter, but the entire light jumps up and illuminates everything...
That doesn't happen with my Cupra... the high beam stays on the ground.
The PIA (Porsche Interauto) workshop says everything is fine. The H7 bulb is simply too weak and I should install H7 LEDs myself, as a brand workshop they are not allowed to install them.
But I’m not interested in a high beam on the ground; I can't see any difference whether the high beam is on or off... But I habitually pull the lever because I think it’s off...
Once with high beam and once without.
Does anyone have experience with this?
Thank you very much.
Best regards, Beroc
Best regards, Beroc
