Program seat memory to key
TiRohn
Hello Forum
I bought a Formentor VZ (model year 21) as a used car and would like to set it up a bit. I use one key myself, and the other is for my wife; we have saved the seats accordingly with the memory positions.
How can I set it so that one key goes to seat position 1 and the other to seat position 2? I have already tried switching back and forth, but then the software messes around with the user settings again, and I obviously don't want that.
I hope you can help me here, thanks in advance!
Regards
TiRohn
I think it works like with the Leon.
Get in, close the door, turn on the ignition, select user profile, hold down 1 or 2 and press the desired key to open, a beep sounds, turn off the ignition, get out and lock the door.
The car must first go into sleep mode for it to work afterwards.
Guten Morgen
Besten Dank für die Antwort, das habe ich schon ein paar mal probiert, aber es fällt immer wieder raus oder kommt erratisch wieder. Muss ich denn auch ein separates Nutzerprofil für den zweiten Schlüssel haben? Wir haben sonst eigentlich alles dieselben Einstellungen...
Gruss und danke
