Questions about camera quality, parking assistance, and blind spot monitoring
DesertMonkey
Hi,
Yesterday I took a test drive and I really like the thing.
The only thing that bothers me a bit, and what I also didn't try enough... Unfortunately, it was already closing time, so I couldn't squeeze any more information out of the dealer...
The rearview camera is really very pixelated, but I could probably live with that.
What surprised me: Maybe someone here has answers.
- Don't the cameras automatically activate when I slowly drive into a parking space? I had to maneuver into a tight entrance and was actually flying blind here.
- There is a top view camera, can I switch between the cameras here, e.g., activate the front camera so I can see how far I can still go forward?
- Is there a collision warning when reversing out? In my current car, it beeps when I back out of a parking space and a car approaches from the right or left...
- Is the blind spot assistant purely visual? Would the car counter-steer if I were to pull over despite an obstacle?
Moin, so as far as I know, you can switch between the cameras, but I would rather not commit to the other points, but the @KrisU from the forum picked it up a few weeks ago and can definitely give you more information here ;)
I thank you already for your response, maybe then the @KrisU a bit more input would make me happy.
Currently, I'm wavering a bit between enthusiasm and "slight" doubts. But actually, it's only about the frills. And strangely enough, no matter which car I've had, something is always different, which other manufacturers have solved better
  • The car doesn't lock itself when you walk away, you have to grab the handle. I think that's great, Renault had that 7 years ago, no idea why BMW or MB don't have it...
  • The camera, on the other hand, even the 360°, is of better quality with MB again, or the differences are "worlds" apart
  • The Drive Assistant in the Tavascan drives significantly "more anticipatively" than with MB, I think that's great since I use it often
  • The HUD with MB is, in my opinion, "clearer and sharper," but the Augmented Reality in the HUD with Cupra is also more beautifully implemented than with MB on the display
  • The blind spot assistant with MB also beeps when I use the turn signal and have overlooked the warning symbol. It has saved my butt once. It also looked to me like the blind spot assistant with Cupra is not active on the right when overtaking. With MB, that was always an indication that I could "pull over" now because I had created enough distance between myself and the overtaken vehicle.
Seriously? This is now the first Cupra I have ordered, and I’m curious to see how I get on with the cruise control. It’s so pleasantly easy to use in MB, so I’ll really have to get used to it, but not buying a car that is also worlds cheaper just because of that?!
I have now given Cupra the chance to excite and convince me; the rest will be shown by time :)
Unfortunately, I only realized after the test drive that you can set the current speed according to signs/navigation by pressing the "Res" button. With MB, I have to double-tap the "Set" button. I found the Manual* setting of km/h with 10 km/h increments nicer with MB. Unless I somehow operated something incorrectly with Cupra.
But even though we, or rather I, only drove about 50 km with the cruise control, I was completely satisfied at first glance, and if the speed recognition works as well as it did during those 50 km (both in the village and on country roads and highways).
Worlds cheaper, well. You can see it that way, but you don't have to. Aside from the fact that the EQA looks terrible when I "quickly click through" and configure it, I only end up with a list price of < 65k. But that question doesn't arise, I find all the MB electric cars unattractive. On the other hand, the Cupra just has style and passion, so there you go. You always have to die a death ;)
@DesertMonkey so I can reassure you, with Cupra you can set the cruise control in 1 km/h increments or in 10 km/h increments, that also works with Cupra, you just have separate buttons for it...
So once with the Set/Res the 10s and with + and - the 1s I mean, or vice versa...
@Tommyinho Thank you very much for your addition. As I said, since I don't have mine yet, I can't say for sure, but I once saw in a video that it works with 1 and 10 steps.
Hi DesertMonkey:
Here are my impressions and experiences with the functions of the Tavascan in RED...
Thank you already for your reply, maybe then the @KrisU A bit more input, I would be happy.
At the moment, I’m wavering a bit between enthusiasm and "slight" doubts. But really only regarding the gimmicks. And strangely enough, no matter which car I had, there’s always something different that other manufacturers have solved better
  • The Benz doesn’t lock itself when you walk away; you have to grab the handle. I think that’s great, Renault had that 7 years ago, no idea why BMW or MB don’t have it...The function takes some getting used to but it works perfectly, at least for me!
  • The camera, including the 360°, is again top quality with MB, or rather the differences are "worlds apart" Unfortunately, I have no comparison with MB so I can’t say anything about that... I find the quality very good..
  • Drive Assistant in the Tavascan drives much more "anticipatively" than with MB, which I find great since I use it often: The Travel Assist works really well, it even works in traffic jams, it brakes and starts moving independently. However, if you stand still for longer than 10 seconds, you have to tap the accelerator briefly and it’s activated again! A really cool function!
  • I find the HUD in MB "clearer and sharper", but the augmented reality in the HUD at Cupra is again more nicely implemented than MB’s display: You can adjust the HUD in the settings to suit your needs.
  • The blind spot assistant in MB also beeps if I indicate and have missed the warning symbol. It has saved my backside once. Also, it seemed to me that the blind spot assistant on the Cupra is not active on the right when overtaking. With MB, that was always an indication that I could now "pull over" because I had created enough distance between me and the overtaken vehicle: The blind spot assistant also reacts acoustically and starts flashing when necessary. Furthermore, the steering wheel vibrates and there is a display in the HUD showing that a vehicle is coming from behind/side. Whether it also gives a warning when you want to merge from the left lane to the right, I haven’t tried yet. But basically, that should also work.
Morning,
Yesterday I went for a test drive and I really like the car.
The only thing that bothers me a bit, and which I also didn’t try enough... Unfortunately, the dealership was already closed, so I couldn’t squeeze any more information out of them...
The reversing camera is really quite pixelated, but maybe that’s something you can live with.
- Don’t the cameras automatically switch on when I slowly drive into a parking bay? I had to manoeuvre into a tight driveway and was basically driving blind...Yes, the cameras switch on automatically and you can then choose which camera you want to see enlarged... I took some pictures of that...
- There is a top-view camera, can I also switch between the cameras here, for example activate the front camera so I can see how far I can still go forward? Yes, that works!!
- Is there a collision warning when reversing out? The car has a parking assistant. If something approaches within the sensor area or a person is detected, the car beeps and brakes sharply. I've already tried that. ..
In my current car, it beeps when I reverse out of a parking space and a car approaches from the right or left...
- Is the blind spot assistant purely visual? Would the car steer against if I tried to pull out despite an obstacle? I haven’t tested it that extremely yet, but I know the steering wheel vibrates and the assistant alerts you both acoustically and visually.
I hope I could help a little!
@KrisU you are our man, since you are one of the first here, many thanks for your insightful explanation and with pictures etc. simply top!!! (y)(y)
Just a quick note on my experience with the reversing camera/top-view camera.
In general, the resolution of the cameras is far too low for a 15-inch display and not up to date.
But unfortunately, this is the case throughout the entire VAG group and is well known.
A classic case of "saving money in the wrong place".
Rückfahrkamera:
Functionality-wise, the reversing camera is absolutely fine.
What bothers me compared to my old Golf is that the camera does not retract when not in use but is constantly exposed to the weather. One night in the rain, I engaged reverse gear and had to laugh out loud at what I could (not) see on the display. :)
However, I forgot to press the camera cleaning button at that moment. Maybe it would have been a bit better then. ;)
Top-view camera:
I find it good for orienting myself with ground markings and curbs.
But when parking as usual, reversing at an angle past another parked car, you only see it completely blurred. Unfortunately, this is totally useless for judging distances. Only the good old glance in the wing mirror helps here.
I had already experienced this with the cameras during my test drive and still decided to buy the car. You certainly learn to work with it. But in my opinion, it is unfortunately not a highlight.
Hallo ihr Lieben, ich Danke Euch recht herzlich! Ich war gestern übelst beschäftigt, weil der Cupra-Händler keien Plugin-Hybride ankauft, und viele andere Händler in der Gegend auch nicht, wie zB mein Mercedes-Stammautohaus :mad:
Deswegen einige Händlerangebote eingeholt, um dann heute bei wirkaufendeinauto.de zu verkaufen. War bei Meilen der beste Preis, fast 10% mehr als bei den Mercedes-Händlern und bei weitem mehr als bei den Freien Händlern. Ankaufpreis war 1:1 wie online angegeben, bin echt begeistert... Muss nur noch das Geld aus Konto kommen :D
Danach gleich den Händler angerufen, dass ich den Vorführer ab November dann nehme 🥳🥳🥳
@KrisU LIeben, lieben Dank für die vielen Ausführungen
Kleine Ergänzung meinerseits:
Ich stelle die 10er Schritte durch "swipen" der +/- Taste in die jeweilige Richtung ein. 1er Schritte, wie oben beschrieben, per drücken auf + oder -.
So oder so kann man aber den Tempomat in 1er und 10er Schritten einstellen.
Das "swipen" will aber erstmal gelernt sein, da musste ich land ausprobieren, bis ich das mal jetzt ein paarmal hinbekommen habe ;)
Noch kurz meine Erfahrungen zur Rückfahrkamera/Top-View-Kamera.
Generell ist die Auflösung der Kameras für ein 15 Zoll Display deutlich zu gering und nicht zeitgemäß.
Aber das ist ja leider im kompletten VAG Konzern so und hinlänglich bekannt.
Klassischer Fall von "am falschen Ende gespart".
Lauf Verkäufer meinte dieser bei der Übergabe, dass es ein Software-Thema sei, und angeblich ein Updat ehinterherkomme für id eKameraqualität. Bin ich ja mal gespannt, wenn nicht muss ich halt öfters mal wieder in die Spiegel gucken beim Rückwärtsfahren :)
Also ich bin "überrascht" wie schlecht die Kameraqualität ist. Gefühlt ist das ein 4:3 Format und hat eine maximale Auflösung 256p. Vielleicht hat ja jemand die tatsächlichen Daten hier?
Die Qualität lässt mich fast schon nostalgisch werden (Motorola RAZR V3 Modell) :ROFLMAO:
Bei Nacht erkenne ich nicht, ob das ein Bordstein ist oder ob die Pflastersteine einfach eine andere/dunklere Farbe haben.
I had already noticed that during the test drive, I was aware of it when I bought the thing. The other "little issues" only came afterward.
But yes, for the vehicle price, the camera is really terrible. Last week, I had a 2024 CLA as a rental car, and here I can see pixel-perfect to the neighboring house, which is about 200m away, and I could even recognize if someone is standing in front of the house...
So these are not worlds, but galaxies...
But thank goodness it at least has the proximity detection, so I don't crash into a passing car while backing out...
Die Frage ist, was ist schlimmer, schlecht sehen oder gar nicht?;)
