Hello, I am new here, I recently got a Formentor. I am interested in what happens to the engine, transmission, and clutch when the tachometer only shows "Ready," that is, in coasting mode. Thank you for the information.
The engine is not off, but the other part is correct, and the ECU lights up on the display when you lightly press the brake; then the engine brake is activated, which you can set in the menu at ECU.
My VZ333 is definitely off in the display when Ready is shown and starts up as soon as I release the brake. I had already wondered what Ready means and just rolled down the window to listen. The engine is off and will be started.
* = Advertisement Links marked with an asterisk (*) are affiliate links. If you click on one of these links and make a purchase, we receive a commission from the respective online shop or provider. This does not affect the price you pay.
