Show total kilometers
RUD
How can I display the total mileage in the cockpit without the coolant, engine, and transmission oil temperature disappearing? According to the operating Manual*, only one of the two functions is possible. Regards, RUD
When you park the car, a screen is displayed that shows the total kilometers. Additionally, in the app or in the infotainment under "Maintenance".
How can I display the total mileage in the cockpit without the coolant, engine, and transmission oil temperature disappearing? According to the operating manual, only one of the two functions is possible. Regards, RUD
Turn off the cruise control on the steering wheel, then a total mileage display will appear in the spot where the cruise control normally is. (Bottom right)
That is no longer possible with the FL; there you can only switch between TA and ACC.
However, you can also display the total kilometers in the infotainment system; it should be under Vehicle Status-Service.
Ah, good to know, I finally have my FL on Friday :)
Of course, my response should also include the vFL info. Unfortunately, we don't have any information about the car from the creator.
That's right, the note is missing, but with the VFL, in my opinion, you can't display the total kilometers there where the TE mentioned.
The image is stolen from a current topic in the neighboring Forum and is only used here for illustration!
After turning off the engine, the total kilometers should definitely be displayed just before the cockpit displays are turned off.
