Soundgenerator?
ChrissD
One-Post-Wonder
Hello everyone, I recently got a Cupra Tavascan and I'm actually very satisfied with the vehicle, but I noticed that the car makes a noise from the speakers when accelerating in Performance and Cupra mode.
In den einschlägigen Videos, in denen die Fahrzeuge vorgestellt werden, wird ausdrücklich darauf hingewiesen,
dass im Cupra-Modus der Motorsound über die Lautsprecher künstlich frisiert wird.
Mal übertrieben so gesagt, der Außenstehende hört ein normales Auto und der Fahrer fühlt sich in einem Rennwagen. :ROFLMAO:
...and the driver feels like they are in a racing car. :ROFLMAO:
Anyone who feels like they are in a racing car with a 1.5l e-hybrid, where a V8 engine is poorly simulated, should see a doctor.
Choose the individual profile and define everything on CUPRA or SPORT, but sounds keep on Comfort.
@cappuccino
I also pulled fuse 59; that disables the unit as well.
However, since then, the oil level sensor shows how much oil is in the engine right from a cold start. Previously, it always needed a warm engine for that.
Is there possibly a connection here that you might be aware of?
So mine has always shown the oil level regardless of the engine temperature. However, I had previously removed the entire module and don’t know it any other way. That was the very first thing I did after delivery when I got home😃
What was it like before? A warning? You just have to plug the fuse back in.
I can always check the oil level then, I think even when the engine is off and only the ignition is on, I need to consciously check that.
Teste ich, sobald er kalt ist und ich ihn wieder hab. Kann natürlich auch Zufall gewesen sein.
(Steht auch so im Handbuch*, wie es @ekm beschreibt)
Danke euch für die Rückmeldung.
@cappuccino Ein furchtbares Geräusch 😁 . Hatte letztens mal kurz auf Cupra-Modus geschaltet, viel zu unnatürlich und irgendwas hat gescheppert und gekrächzt aus dem Soundmodullautsprecher. Wenn die wenigstens die Sennheiseranlage dafür genommen hätten…
Also wenn ich das alles hier so lese... irgendwelcher Online-Kram, der nicht funktioniert, flackernde Ambientebeleuchtung, krächzender Soundgenerator, polterndes Fahrwerk, vibrierender Antriebsstrang... meine Herr'n... wurden die Cupras in den letzten 5 Jahren alle komplett nur verschlechtert, oder wie??? All diese Probleme hat meiner der ersten Serie aus 2021 alles nicht. Das ist ja alles nicht zu fassen!!!
Ja gut, die Meisten haben ja nicht alle Probleme gleichzeitig. Es ist eher ein Problem pro Fahrzeug, manchmal auch zwei. So schlecht sind sie nicht geworden, wie man es sich hier zusammenreimen kann, wenn man es will.
Heute mit eingebauter Sicherung probiert, zeigt auch direkt den Ölstand an…
Komisch…
War dann wohl Zufall :D
Nachdem jetzt paar mal die Batterie abgeklemmt war (Werkstatt), zeigt er kalt, wie vorher auch, wieder an, dass der Motor erst warm sein muß, bevor gemessen wird. 🤷‍♂️
Gerade in der Mittagspause bei mir nochmal getestet. Bei 3° Außentemparatur auf dem Außenparplatz reingestetzt, Motor an, .. Ölanzeige ist da.
This morning he immediately showed the oil level again 🤷‍♂️ Who knows what parameters all this depends on... If worst comes to worst, I still have a real dipstick 😁
