Start/Stop system defective, but Cupra refuses
warlow
Hello everyone,
I have a Formentor VZ 333 PS from 03/2025, so it's a facelift model.
Right now, I'm feeling quite frustrated because the workshop can't do anything, and Cupra itself, after multiple email exchanges, not willing The goal is to find the cause of the problem. Here’s what I mean:
Since about early 05/2025, the engine no longer turns off, neither while coasting nor when stationary with increased pressure on the brake pedal
* 21.06. (about 3 km after starting) and 22.06. (in traffic on the motorway) it worked
* 22./23.06. the automatic worked
* 28.06. driving distance 4.5 km, outbound trip works immediately and continuously, 1 hour later return trip does not work at all
* 30.06. works irregularly, but fundamentally yes
* 01.07. driving distance 4 km, outbound trip works immediately and continuously, 15 minutes later return trip does not work at all
* 02.07. driving distance 9 km, outbound trip works, 1 hour later return trip does not work at all
* 05.07. driving distance 4.5 km, outbound trip works immediately and continuously, 45 minutes later return trip does not work at all
* 07.07. in the morning driving distance 9 km without function, in the afternoon driving distance 12 km without function
* since mid-July, permanently no function again
To find out the reasons, the protocol was read out in the workshop. The most frequently noted reason there was essentially "driving situation," but no one could explain to me what that includes. So it lacks significance, and I could already tell from the numbers on the individual points that this was never the number of times the engine had not turned off. But I am just a layman...
In any case, no defect is detected, although the start/stop automatic definitely does not work.
I don’t want to subject you to the email responses from Cupra, all dismissing in anticipation of higher costs.
By the way, there was also the case that in the morning when opening the garage, the tailgate was open, the vehicle lighting was on, and the vehicle was still locked. Absolutely excellent if that were to happen on public ground...
Now two questions for you:
1. Has anyone also noticed issues with this shabby and flea-ridden start/stop automatic, and if so, how do you respond to it?
2. Is anyone aware of how to escalate beyond the standard helpdesk of Cupra? I am considering raising this issue a bit higher.
I hope that none of you have this problem, but I would also appreciate suggestions/tips in that case.
Have a nice weekend, community
Warlow
Problem war also nicht von Anfang an sondern begann im Juni, richtig? Gab es davor evtl. ein Update?
Ich habe zwar nur den eTSI, aber mir ist in den letzten Wochen auch das ein oder andere Mal aufgefallen, dass der Motor im machen Situationen auch nicht wie gewohnt ausgeht (obwohl z. B. Temperatur ausreichend vorhanden ist).
Also ich wäre bei einigen meiner Autos sogar froh, wenn die Start-Stopp-Automatik generell nicht funktionieren würde. So aber muss ich nach jedem Motorstart den Kram händisch per Tastendruck deaktivieren, um vor der elektronischen Bevormundung meine Ruhe zu haben.
Ich habe zwar meinen cupra noch nicht, aber vielleicht helfen ein paar informationen, die ich aus meinem golf kenne.
vorab; ich fahre generell ohne start/stopp automatik. entweder man schaltet ihn manuell aus oder geht in einen der sportmodis. der sportmodus sorgt bei mir ebenfalls dafür, dass die start/stopp funktion deaktiviert ist. ansonsten sorgen sehr hohe und niedrige temperaturen oft dafür, dass der motor an bleibt. vielleicht trifft ja eines der 3 punkte darauf zu.
Also aufgrund der Beschreibung - Fehler oft auf dem Rückweg - und dem Auslesen - "Fahrsituation" - hätte ich die Theorie:
Die Automatik geht ja "geplant" aus, wenn so etwas wie Stop and Go erkannt wird, d.h. nach ein paar mal SSA in Stau bleibt der Motor erst mal an, Punkt.
Das erkennt bzw bewertet das Fahrzeug selbst und ist so nicht transparent oder messbar..
Bei dir macht es den Anschein, als würde irgendetwas auf der ersten Fahrt genau das auslösen - "gewollt" oder fehlerhaft lasse ich mal offen. Und auf der Rückfahrt kommt er aus diesem Modus der deaktivieren SSA nicht mehr heraus.. das wäre dann definitiv nicht Sinn der Sache..
Wie ist es denn, wenn du bei dem Fehlerbild über das Menü die SSA deaktivierst und nach 1 min wieder eingeschaltest: Reicht so ein Impuls, um es wieder in Gang zu bringen?
Viele Kurzstrecken... Vielleicht muss der opf mal regeneriert werden?
Das wäre eine mögliche Theorie, wäre in dem Fall nur gut, wenn da auch ein Hinweis kommt, so wie ich es von TDIs mit DPF kenne.
Der sollte eigentlich auch kommen. Mein Karoq hätte eigentlich auch immer anzeigen sollen, wenn die Schlüsselbatterie schwach wird - hat er nie. Deswegen würde ich mich nicht drauf verlassen.
Ich glaube, zum Regenerationszyklus steht was im Handbuch*....
Ist doch einen Versuch wert, oder?
Sonst hilft nur Beschwerdebrief per Einschreiben an den chef von Cupra Deutschland
Es gab tatsächlich Updates, allerdings hätte ich mir nie träumen lassen, die auch noch (chronologisch) protokollieren zu müssen. Ist also schwierig zu beurteilen.
Kann ich tatsächlich alles ausschließen, aber danke für die Hinweise
Das hatte ich anfänglich ohne Erfolg ausprobiert (allerdings ohne die "Wartezeit"), aber ich werde es die nächste Zeit auch testen. Denkbar ist so etwas ...
Ich glaube, zum Regenerationszyklus steht was im Handbuch....
Danke für den Hinweis mit dem Handbuch*.
Und jetzt muss ich nur noch die Anschrift von dem Cupra-Chef ermitteln
Im Handbuch* ab Seite 189 werden so viele Möglichkeiten benannt, warum bzw. unter welchen Bedingungen das Start-Stop-System nicht funktionieren kann.
Mir persönlich ist es aufgefallen, dass es z.b. nicht funktioniert, wenn ich komplett auf Travel-Assist fahre / fahren lasse.
Unabhängig davon stört es mich persönlich auch nicht, wenn der Motor anbleibt, weshalb ich bei mir auch gar nicht auf sowas speziell achte.
Wenn du dir sicher bist, dass es bei dir unter Abwägung der Ausschlusskriterien im Handbuch* dennoch funktionieren sollte/müsste, dann bleibt nur eine offizielle Mangelanzeige und schlussendlich das einschalten eines Gutachters für eine Nachweisführung.
Genau @Melfinos. Es gibt tatsächlich eine ganze Reihe von Bedingungen für S/S.
Z.b. zu hohe Aussentemperatur, zu hohe Luftfeuchtigkeit innen, schwache Batterie (im Ernst: dein Auto ist 1 Jahr alt und du hast offensichtlich viele Kurzstrecken... die Batterie könnte tatsächlich auch einen Treffer haben, was mich nicht überraschen würde. Seit 2010 haben alle meine VW-Konzernautos innerhalb der Garantie eine neue Batterie gebraucht), oder der Marder hat dir das dünne Kabel vom Batteriewächter abgeknabbert...
Du kannst auch mal die Batterie ordentlich aufladen. Vielleicht langt das schon.
PS: Geschäftsführer und Adresse findest du normalerweise auf der Webseite im Impressum.
Danke euch beiden.
Die Bedingungen gem. S. 189 und auch der Aussagen des Händlers, die ein Ausschalten des Motors verhindern, treffen sicher das eine oder andere seltene Mal zu. Hätte ich auch akzeptiert, kein Thema, aber dass die Funktion gar nicht mehr funktioniert, zumal sie anfänglich normal gelaufen ist, weist für mich auf einen Fehler hin oder einen Zustand, den ich und der Händler nicht kenne/kennt.
Wenn Cupra sich allerdings pauschal weigert, nähere Untersuchungen einzuleiten, nur weil das (unzureichende) Protokoll das nicht hergibt (schallendes Gelächter!), kann ich das nicht akzeptieren. Mir ist bewusst, dass so eine tiefere Untersuchung Geld kosten würde, was Cupra natürlich vermeiden will.
Ich sehe mich tatsächlich schon vor meinem ersten Rechtsstreit im Leben (brech, würg), werde aber vorher den Herrn Geschäftsführer anschreiben.
I hope you don't want to take legal action just because a currently possibly non-functioning start-stop system?
Basically, you would have a defect if it doesn't work at all, and that would already make legal action possible. Please don't misunderstand me for this reason.
I wouldn't make any efforts just because of the start-stop system, considering the effort and costs for proving it through an expert opinion
As I said, this is my personal opinion. I would at least report the defect and do so repeatedly. But taking legal action with costs would be a no-go for me just because of this one system.
If you decide to go for it, I wish you much success and feel free to keep us updated. I would really be interested to know how long it takes and what the success and costs are, etc.
@warlow
Apparently, you have no idea how much effort, time, nerves, trouble, and endurance such a legal dispute will cost you. So, to take legal action over something trivial like whether start-stop works in certain situations or not, I find completely exaggerated and absurd. My opinion. But maybe one has to be, like me, 60 years old and have a certain life experience to be able to judge something like this with more calmness. My opinion. And I also don't believe that a legal protection insurance would "cover" this. I can't imagine that. You would need to provide solid, verifiable parameters under which start-stop must function, and you can't do that.
Servus ich habe auch eine frage über das start stop gestellt schau mal nach da sind viele Parameter die passen müssen wußte ich auch nicht dafür sind wir ja hier man muss nicht unter die Gürtellinie gehen vielleicht hat das geholfen Gruß Harry
