Successfully picked up Leon 204 PS 4Drive!
Invio1
Forenfan ★★★
NATO
So, I finally managed to pick him up today, the Leon 204 PS 4Drive 😁. I meticulously checked everything during the handover; no paint damage, no scratches outside or inside, everything is in order.
The Leon ST drives really great; smooth and quick acceleration, no "stuttering" when braking, excellent cornering, well insulated for a non-premium vehicle. I can't say much about the acceleration yet because I'm still taking it easy. I've only driven up to 120 km/h and only with moderate acceleration. I didn't really pay attention to the consumption, it was something around 9l and I mostly drove in the city. It will get better. I still need to get used to the menus and the navigation of the digital speedometer.
After a total of about 45 km of driving since pickup, I treated him to Super Plus for the first time, even though according to the fuel cap it isn't necessary and regular Super is sufficient. I will fill up with that irregularly from time to time. At pickup, there were even 200 km of remaining range left, which pleasantly surprised me a bit.
At the dealer's lot, the infotainment system didn't work properly, and we couldn't set up the app/CupraID, etc. After driving for about 2 hours, I managed to do it without any issues, including the authentication with both keys in the vehicle and the online identity verification in the app. Everything worked immediately :D. However, during the setup, I was notified in a popup window that "New settings are available." I clicked "Cancel" there. Since then, that message hasn't appeared again. Hopefully, it stays that way. Otherwise, it beeps a bit too much for me, after starting the engine and when the engine is running and the driver's door (or any door?) is opened. But whatever, that's normal these days.
Travel Assist didn't adjust the speed based on the signs for me. I still need to check what the issue is. I only found a setting for that under "ACC." Are they related :unsure:?
Software version see one of the pictures. The "B" at the end is probably the latest hardware, right? There seems to be an update available that I haven't initiated yet. Question regarding this: How long does an update take approximately, and does the engine need to be running, or can I initiate it, turn off the engine, and lock the car? With Kia, it continued anyway. Otherwise, the updates there took about 40 minutes, at least via USB stick.
Soon I will take a drive in the dark to test the lights. I'm curious how much better it is than my previous Kia, but also whether and to what extent it is worse than the matrix lights with adaptive cornering lights from my Ford Focus before the Kia.
All in all, I'm very satisfied so far 👍.
Schöner Bericht und tolle Fotos. (y) Ich wünsche Dir allzeit gute Fahrt.
Danke sehr, ich hoffe auf ein Miteinander möglichst ohne die Softwareprobleme, die manche Leute hier haben. So weit so gut. Obwohl die Ambientebeleuchtung ganz kurz Mal geflackert hat. Es war aber ein Paar Sekunden, nachdem ich deren Einstellungen geändert habe, könte also damit zusammenhängen. Auch kam die Popup-Meldung mit "Neue Einstellungen sind verfügbar" leider wieder. Habe sie wieder mal abgebrochen. Beim nächsten Mal werde ich sie evtl. annehmen und schauen, was passiert.
Das Matrixlicht funktioniert wie erwartet super, es gab keine einzige Lichthupe. Das Lichtspiel ist halt ziemlich auffällig, weil es schnell passiert. Bin das von Ford unaffälliger dank stufenweisem Dimmen und Aufblenden gewohnt. Egal, hauptsache wieder Matrix und allgemein etwas stärkeres Licht als beim Kia.
Es gab dann doch kein Systemupdate, nur ein App-Update. Rest ist wohl aktuell.
Ich habe auch rausgefunden, dass die Einstellungen in den Reitern "Travel Assist" und "ACC" tatsächlich zusammenhängen. Travel Assist hat seitdem die Schilder richtig erkannt und die Geschwindigkeit angepasst. Ich dachte allerdings, dass er das schon im Voraus tun würde und nicht erst ab Schild. Bei VW geht das so, wenn ich mich nicht täusche.
Was ich noch rausfinden muss:
Wo stelle ich die automatische Türöffnung und -schließung ein bei Annäherung bzw. beim Entfernen vom Fahrzeug?
Warum geht der Motor automatisch aus, wenn ich N einlege, P drücke und Parkbremse betätige. Hat mich vorhin gewundert, als ich vor der Garage stand, Fahrzeug verlassen habe, um diese zu öffnen und dann der Motor aus war. Hat bisher keines meiner Fahrzeuge gemacht. Hängt das davon ab, ob der Schlüssel im fahrzeug verbleibt?
Warum das Ziehen des Blinkerhebels während der Fahrt manchmal Lichthupe macht (wie es soll) und manchmal nur den Fernlichtassistenten ausmacht. Um ihn auszumachen muss ich leider den Hebel nochmal drücken, damit normales Fernlicht angeht und dann erst geht er durch einmaliges ziehen aus. Kenne noch keinen anderen Weg.
Ob es normal ist, dass die Leuchte am Schlüssel dauerhaft blinkt, wenn man sich im oder am Fahrzeug befindet.
Warum das Ziehen des Blinkerhebels während der Fahrt manchmal Lichthupe macht ...
Wenn man N oder P einlegt, weiß das auto, dass du nicht fahren kannst und aktiviert die startstopp automatik. stellst du die SSA aus, dann geht auch der motor nicht aus. das ist unabhängig davon, ob der schlüssel da ist oder nicht. kleiner zusätzliche info; wenn du dein auto mit schlüssel verlässt, während sich das auto in der stoppautomatik befindet, dann schaltet sich der motor nach relativ kurzer zeit richtig aus. sicherheitsvorkehrung.
zum 2. punkt. als aufmerksamer autofahrer sieht man hin und wieder mal fahrzeuge, die zum blinken 1x kurz lichthupe geben. das hat mit demm fahrzeug nichts zu tun, sondern mit dem fahrer. i.d.r. zieht die person beim aktivieren des blinkers, den hebel etwas zu sich, was dann die lichthupe auslöst. ich denke aber, dass es je nach modell schneller oder weniger schnell passieren kann.
Edit: herzlichen glückwunsch zu deinem fahrzeug und viel freude daran :)
Guten Morgen und Glückwunsch zum neuen Cupra. 🥳
Öffnen/Schließen bei Annäherung:
Fahrzeug > Außen > öffnen/Schließen
Travel Assist: das kann dein Cupra auch. Die "Geschwindigkeitsbegrenzung" muss halt in der Datenbank "hinterlegt" sein, damit er vorher schon die Geschwindigkeit reduziert. Ist leider nicht immer der Fall, somit wirft er dann den Anker wenn er ein Straßenschild erkennt.
@Invio1 Hi, first of all, congratulations, I'm really happy for you, the wait is over!! :)
What engine options did you have before, how far can you compare starting off in general and driving in city traffic?
To your questions:
Gasoline: then the 95 should be completely sufficient, without any loss of power. The 98 shouldn't make any difference - if you want to "treat" the engine a bit, you could fill up with Vpower or Ultimate (topic of cleaning additives).
The initial setup also only worked for me the next day.. either the system isn't quite ready yet, being so "fresh," or simply poor reception or too many keys at the dealer nearby... but my experience was the same, it worked flawlessly afterward.
The "settings are available" message CAN come up from time to time.. it's basically server-side controlled. You can go into the user menu and sync manually. Also, observe whether the timestamp really matches the current time. I had problems with that in the first months and noticed that during the current sync, although it was successful, the wrong time was displayed until it was switched to daylight saving time, which probably gave the necessary "kick."
Assistants:
ACC is basically a "smart cruise control": you set the speed. The Front Assist also maintains the set distance, and the camera recognizes the traffic signs. Travel Assist then goes into semi-autonomous driving, pulling in lane data via GPS, and here it adjusts the speed appropriately BEFORE the sign. The icing on the cake is using it with active navigation.
Hardware B was the latest version last. A C version has apparently already been spotted with the Formentor, I don't know if it's vehicle-dependent or reserved for MJ26. But definitely more current than the "early facelifts."
The really big updates are only available at the service partner, everything else are just small "app" updates.
Kessy and which doors unlock is in the vehicle settings, just click through every conceivable menu and submenu at your leisure. ;)
The engine stalling quickly also happened to me and is annoying when you just go to the trunk briefly before parking.. when I returned to the driver's door, it always just shut off for me, so I really had to restart the ignition and engine to park. I then got into the habit of activating the start-stop automatic when entering the garage. I’m probably one of the few who don’t clash with the SSA and keep it active while driving.
Let me know if you notice anything else and safe travels!!! :)
Fernlichtassi:
Zum Abschalten entweder die Lichtautomatik abschalten
Oder
Wenn Assi aktiv ist, Blinkerhebel mit Lichthupenbewegung
Oder
Wenn Assi aktiv, aber gerade kein Fernlicht leuchtet (zb Innerorts): Blinkerhebel nach vorne (schaltet FL manuell ein, das A in der blauen Lampe verschwindet) und dann Lichthupenbewegung > blaue Lampe geht aus.
Vielen Dank an euch, ich habe mir einige Dinge mal aufgeschrieben und werde sie evtl. heute noch austesten.
@coopra , von den Automatikfahrzeugen hatte ich einen einen Ford Focus Benziner von der noch aktuellen Generation mit 182 PS Frontantrieb und den Kia ProCeed Benziner mit 160 PS, den ich bis letzte Woche noch gefahren bin. Davor nur Fahrzeuge mit Schaltgetriebe. So gesehen habe ich jetzt nicht so riesig viel Vergleich zu anderen Automatikfahrzeugen.
Der Focus hatte eine 8-Gang Wandlerautomatik, der Kia ein 7-Gang DCT (DSG). Beim Focus war die Reaktion und der Kraftschluß beim Anfahren und Beschleunigen aus dem Stand direkt da, wie jetzt beim Leon, wobei der Leon noch etwas besser beschleunigt dank Allrad. Beim ProCeed war das Anfahren teilweise eher schlecht. Focus und Leon haben keine Gedenksekunde nach Gaspedal drücken, der Kia schon. Allrad hilft heir sicherlich auch, wobei man kein Drücken von hinten extra spürt.
Soweit ruckelfreies Schalten, wobei ich natürlich noch kein Kickdown ausprobiert habe. Bei der Fahrt im Dunkelt gestern musste ich aber einen Trödler-Golffahrer überholen, der bei erlaubten 100 km/h gerade mal 50 km/h gefahren ist und den sonst auch alle überholt haben. Das war ziemlich bergauf und dafür, dass ich nicht viel Gas gegeben habe, war ich echt schnell an ihm vorbei.
In der Stadt habe ich an sich noch keinen Unterschied entdeckt, außer halt das zügige Anfahren (und mehr Verbrauch als bei den anderen beiden 😅 ).
@Shaun , alles klar, dann liegt es an der StartStop... Macht Sinn. Die Male, wo der Motor nicht ausging, war sie wohl ausgeschaltet.
@Muffi , Diesen Menüpunkt habe ich dann wohl übersehen.
@Schmitzibu , danke, das erklärt alles. Dann habe ich das richtig wahrgenommen und weiß jetzt auch, woran es lag. Auf der Landstraße konnte ich durch Hebel ziehen (normalerweise für Lichthupe) den Fernlichassi ausschalten. Als ich es dann im Gewerbegebiet bei mir um die Ecke austesten wollte, der teilweise Straßenbeleuchtung hat, hat es dann nur Lichthupe gemacht. Ist also genauso gewollt.
Frage... Wie stelle ich denn nun die Funktion der Beifahrerspiegel-Absenkung richtig ein? Ich habe es jetzt mehrmals versucht und von allem, was der Leon zu bieten hat, ist das die eine Fuktion, die einfach nicht so richtig will... Mal ist es dann runtergefahren, danach aber statt in die Ausgangsstellung nur ca. 1 cm nach oben und hat gestoppt, dann hat es gar nicht funktioniert usw.
Lt. Anleitung*: Zündung an, es muss N und P drin sein, dann eine beliebige Memory-Taste drücken, R einlegen, Spiegel verstellen und es soll dann bereits gespeichert sein. Pustekuchen. Ideen?
Ansonsten noch zum Verbrauch, für Diejenigen, die es interessiert:
Mit überwiegend Land- und Stadfahrten sitzt der Verbrauch seit Tanken beim Durchscnitt von 8,4 l/100 km. Wird denke ich noch besser, wobei es jetzt schon nicht schlechter ist, als mein damaliger Ford Focus mit 182 PS und ohne Allrad. Am Freitag fahre ich eventuell die erste Langstrecke. Mal schauen, wie es dann aussieht.
Das automatische Öffnen/Schließen habe ich hinbekommen, funktioniert soweit zu 100% verlässlich.
Raising to the starting position only occurs at a speed greater than 15 km/h.
The saving process is only completed when the reverse gear is disengaged. (Switching to D) Did you possibly turn off the car immediately after the setting?
@Invio1, Herzlichen Glückwunsch zum ersten 204er hier im Forum.
Allzeit Gute Fahrt!
Noch 2x schlafen ;).......dann ist es bei uns soweit.
Thanks Chris1, yeah awesome, you then have the second 204 here :D. Apart from the paintwork, everything else in terms of equipment seems to be the same as mine. Then you can see if you share my description of the driving experience.
Regarding the mirror: Is the right mirror still selected using the rotary control? The automatic only moves to the chosen position if it is permanently set to R. If it is set to L or mirror heating etc., you first have to turn it to R and then engage reverse gear.
The mirror only moves up to the starting position at speeds above 15km/h.
The memory process is only completed when reverse gear is disengaged again (switching to D). Did you perhaps switch off the car immediately after the setting?
Thanks for the clarification 👍. I didn’t leave the switch on R and didn’t drive afterwards, so yes, I turned off the engine. Today I’ll try that again before driving.
@Invio1, I will report back.
That's right, the equipment is pretty much the same.
The difference must then be in the model year.
You have model year 2025, right?
Right, MJ25. I'm curious to see what software version you and coopra have and what you say about the driving behaviour.
Honestly, I find the grey accents of the MJ 25 with the colour Graphene Grey even better than with black. I was standing in front of and behind the car earlier and imagined it in black. That would have been nice too, but less harmonious.
Zum hochfahren des Spiegels reicht es auch, den Drehregler wieder aus der R-Stellung zu drehen und man sollte warten bis er die Ausgangsposition erreicht hat.
@Invio1 Kannst du zufällig mal in den Papieren (ECE?) nachsehen, welche Bremsen von und hinten verbaut sind?
Mir konnte nämlich im Vorfeld niemand beantworten, ob Bremsanlage und Auspuffanlage beim 204er eher Richtung 1.5er gehen oder doch schon einen Schritt Richtung VZ... :unsure:
Der WhatsApp Support sagte sogar, der käme mit echten Endrohren, was zu schön wäre um wahr zu sein, und ja offenbar auch nicht ist 😅
So, heute war es auch bei uns soweit :).
Es stand ein vollgetanktes Auto beim Händler.
Hat mich gewundert und natürlich auch gefreut.
Er ist seit über einer Woche angemeldet....
Es klappte auch nicht mit der App/CupraID 😂.
Nachdem eine ca. 30 minütige Einweisung erfolgte, klappte es dann aber doch.
Der Rückweg, ca. 70 km war wirklich ein Genuss.
Sehr gute Lage auf der Straße, ich finde es sogar sehr leise ( okay, das bisherige (Leon ST FR)hat auch 10 Jahre auf dem Buckel).
Zur Beschleunigung kann ich auch noch nichts sagen.
Autobahn, Landstraße und Stadverkehr, Höchstgeschwindigkeit 125 km/h, Durchschnittsverbrauch 7,4 Liter.
Mit der ganzen Technik u.s.w. muss ich mich noch ausgiebig beschäftigen.
Bis jetzt auf jeden Fall zufrieden.
Meinst du das COC-Papier? Da steht nix zu bremsen. Es sind aber "normale 0815-Bremsen" vom Aussehen her. Habe da auch nix anderes erwartet. Bremsen trotzdem gut. Heute bin ich zwei Mal Langstrecke gefahren, naja zumindest ca. 320km in beide Richtungen. Einfach mal einen Ausflug gemacht und nebenbei Auto etwas eingefahren. Hat jetzt ca. 840 km drauf. Bin fast durchgehend mit 125-130 km/h gefahren, stellenweise aber auch kurz mal 140-145, wo die Situation es erfordert hat. Travel Assist funktioniert auch wunderbar, auch im Stau (wie kann man in Deutschland auch nur 200 km weit fahren, ohne in einen zu geraten? 😅).
Verbrauch siehe Bild aus der App. 7 l finde ich voll OK für die gefahrene Geschwindigkeit :D. Es waren etwas über 600 km, kA warum da 596 gefahrene KM steht. Verbrauch lt. Tacho Durchschnitt 6,7 l.
na endrohre hat jeder verbrenner. bei den einen siehst du sie, bei den anderen nicht :D
Optisch unterscheiden sich eTSI und der 204PSer nicht, jedenfalls habe ich bis jetzt keinen gefunden. Man hätte da wenigstens den Schriftzug schwarz oder die Blenden Silber machen können, um irgendeinen Anhaltspunkt zu geben. Am besten wäre mMn einfach klassisch nur auf der linken Seite sichtbare Endrohre.
