Tachosignal?
JoergFB58
Forenfan ★★★
Where does the speed signal actually come from?
ABS?
Transmission?
GPS?
In other words, how accurate are the speed readings in the instrument cluster? Are different tyre circumferences, slip, etc. also taken into account?
m.W. wird die Geschwindigkeit (Strecke) über den Reifenumfang gemessen. Die Tachos werden mit einer "Standard" Bereifung kalibriert. Unterschiedliche Profiltiefen (abgefahrene Reifen), Luftdruck, untersch. Felgengrößen und Flankenhöhen sind schon meßbar. Deswegen dürfen Geschwindigkeitsanzeigen nie eine kleinere Geschwindigkeit anzeigen, als man tats. fährt. Der Tacho zeigt deshalb etwas mehr an. Die Anzeige ist also nie ganz genau. Wechselt man auf ganz krasse Rad-/ Reifenkombinationen muß, glaube ich, auch der Tacho neu kalibriert werden. Wer eine genaue Geschwindigkeitsanzeige möchte, kann dies z.B. über GPS machen.
If you switch to really extreme wheel/tire combinations, I believe the speedometer also needs to be recalibrated.
With my GTI, I actually had to do a speedometer adjustment with the tire size 235/35R19. Fortunately, it was within tolerance and nothing needed to be calibrated. I wouldn't have had to do that with 225/35 R19.
I am aware of the legal regulations. A maximum of +10% plus an additional 4 km/h, meaning that at a real speed of 100 km/h the speedometer may show 100 + 10 + 4 = 114 km/h, but never less. Although there may also be tolerances of up to -1% allowed there.
With my previous vehicles, including the current motorcycles, the speedometers usually showed 5 km/h too much.
Different tyre brands, tyre wear, air pressure, and at higher speeds slip and sensor variations can also lead to significant deviations.
I am fully aware of all this, of course. That is exactly why I am asking.
Depending on where the signal comes from, it can be more accurate (GPS) or not (wheel speed sensors), especially if it comes from the drive axle.
