Tank volume Cupra Leon 1.5 eTSI DSG Sedan
Thomas
Does anyone know the exact fuel tank capacity of the Cupra Leon 1.5 eTSI DSG sedan!? The internet always states different things! 40L or 45L or 50L = Everything can be found!
In the technical data online, it says 50L but I don't really believe that, because in the online Manual* it states 45L + 7L reserve = 52L total (Is that correct???)
And is the fuel gauge accurate for how far you can still drive? I had 50km left and then refueled and filled 49.47L! So I assume a 52L tank including reserve.
Can someone confirm this?!
I had 50 km left and then refueled with 49.47 L!
What does your onboard Manual* say about the tank volume?
From other brands, I know that manufacturers often "conceal" a "silent reserve" in the specifications for tank volume, which the tank still accommodates, such as the difference of 2 liters, so that the figures in the onboard Manual* can be understood as "minimum tank volume." This could explain the different figures of 50 L and 52 L that you found online.
0.53 L remaining for 50 km would correspond to 1.06 L/100 km. So, a real tank volume of 50 L seems very unlikely. A bit more seems probable according to the aforementioned theory.
I have NEVER run the tank empty. Then you would know for sure. ;)🤣
p.s.: On carwiki, the tank volume is listed as 50 L, the plug-in hybrid with 40 L.
Does anyone know the exact fuel tank capacity of the Cupra Leon 1.5 eTSI DSG sedan!? The internet always states something different! 40L or 45L or 50L = Everything can be found! The technical data online states 50L, but I don't really believe that, because the online manual states 45L + 7L reserve = 52L total (Is that correct???) And is the fuel gauge accurate for how far you can still drive? I had 50km left and then refueled and took 49.47L! So I assume a 52L tank including reserve. Can anyone confirm this?!
Standard is 45L. You get 50L if you add DCC. Hybrid has less space, so only 40L. (But irrelevant for your question regarding eTSI) ;)
PS:
Beim eTSI musst du eine der 19" Felgen nehmen um DCC zu erhalten. Bei den VZ-Modellen ist DCC Serie.
Ich hätte das DCC auch lieber als extra Paket gehabt, da ich keine 19"er wollte (macht halt beim 150PS für mich keine Sinn). Bei den alten 1.4er e-Hybrid ging es auch mit dem DCC in Kombi mit den 18" Felgen.
Im Nachhinein hätte ich es doch wählen sollen (weil DCC+5 L mehr Tank) und dann die 19" gegen 18" mit Ganzjahresreifen tauschen können.
in welchem Paket ist das DCC dabei? Konnte es im konfigurator weder einzeln, noch in Paketen finden.
Im Konfigurator müsste es bei der Auswahl der Felgen dabei stehen. 19"++DCC++MehrlenkerHA (Einzelradaufhängig) sind fest gekoppelt.
In der Preisliste heißt das irgendwie Driver/Performance-Paket...
Bisher hatte ich den Seat Leon 5F von 2015 als FR, Hatchback, mit 125 PS und 17" - nun den Cupra als Kombi mit 150PS eTSI und eben 19"er und DCC.
And what do you think now about what fuel tank capacity you have and how much reserve! I had read 45L tank capacity + 7L reserve!?
What is the question here, what else is there to guess..?
The tank capacity is clearly defined. Obviously, there is still some fuel left in the lines, but no one will probably run the tank completely empty just to test it.
No offence intended, but what is this still about, please..?
I think the question is how to interpret the specification, that is, whether it includes the reserve or not. For my old Passat, 70 litres were specified; I filled up a maximum of 66 litres, and according to the fuel gauge, there was still 0 km range left.
Now, some people here have managed to put more fuel into the tank of the Leon than specified, so it is assumed that the specification here is without reserve.
For the 1.4 VFL, the specification of 40 litres definitely includes the reserve, as I always filled up less than 40 litres, even with only a few kilometres of range left.
I checked, so far I have refuelled twice
1. 48.3L, remaining range around 20km
2. 45.6L, remaining range around 100km
I have the eTSI, Leon ST, facelift, with the 50L tank.
Also, the factory specification including reserve. Are you generally correct with the remaining range being around 5L/100km?
No, currently I am still breaking in the car, about 7L/100km. I have read values of 5.5L for the eTSI before, but I have no idea how that is supposed to work, unless you only roll over country roads...
I estimate that the tank volume is really to be seen as net! 50L for me is quite accurate, considering what I have refueled...
What does "reserve" always mean? What is still in the lines??
I have listed above, including the catalog, under what conditions you get which tank - the manufacturer does differentiate there. I am just surprised by statements like this, as if there is cheating going on (50 including "reserve") or similar.
It is written in black and white. And it matches what you actually get.
