Terramar Charging Edge Protection
Geude morge marc
Sieht gut aus. Zusätzlich suche ich noch aus Edelstahl gebürstet ein abdeckblech auf die geriffelte Stelle beim Kofferraum Schloss , verstehst du was ich meine.
Ich bräuchte den Schutz wegen den Hunden..
Gruß Andreas
Uff, da bin ich raus, das finde ich nicht auf die schnelle...
Sowas gabs für den Tiguan 2. Für den Terra hab ich noch nichts in der Art gesehen.
Vielleicht passt von diesem Set für den neuesten Tiguan das Innenteil?
The Audi Q3 comes with such aluminum/steel parts in the boot as standard (or at least in some equipment lines). Since the Terramar and Q3 are quite similar, the rear panel trim from Audi COULD also fit the Terri. However, it is certainly not cheap. The Ateca definitely does not fit. Completely different car...
I don't think that fits between the Terramar and Q3. The curvature of the edge is likely not the same.
I think so, but you only know for sure when you try it out. However, the Audi parts are expensive. Too expensive for a trial on a whim.
please help me continue searching..
yes, good.
With "loading edge protection," it is usually meant the edge of the bumper, as far as I know. You are also asking about a cover for the cover on the frame next to the lock carrier. The colleagues above have already put in some effort regarding that.
For questions where OEM doesn't fit, I am always pragmatic with the motto "doesn't have to win a beauty prize but must work." How about an old wool blanket, a painter's fleece, a rubber mat, or a self-adhesive film?
Just have a transparent protective film applied by the wrapper 😉
The classic loading edge (= top of the bumper) is not really a problem on the Terramar. When the trunk is open, it goes almost vertically down to the license plate in the middle. Almost no area that could be sensibly covered with a sticker. At least that's my feeling (and yes: I had these films on the bumper with both predecessor cars - Scirocco and Karoq).
In my opinion, it would actually make more sense to have an aluminum or stainless steel cover on the plastic part to the left and right of the lock, like the Q3 has. So basically inside the trunk.
Of course, you can also attach a felt mat to the trunk floor and unfold it as needed.
If there are already scratches, a self-adhesive carpet fleece or adhesive felt on the cover might also work. Heat up deep scratches beforehand and press them flat.
