The "small" Cupra Leon ST
Pat89
So folks, let me introduce you to my Cupra:
You could say it's a sheep in wolf's clothing 😅
Cupra Leon ST 1.5 eTSI in Fjord Blue:
I particularly like the Dinamica seats with the floor mats ❤️
You can't say anything about the consumption yet, as you've only driven 90 km.
But there are already two negative points:
- When two phones are connected with Apple CarPlay, you can't switch back and forth between the two; in my Tarraco, there was a button where you could easily jump to the other phone and back, in the Leon you have to go through a complicated menu, etc. But maybe one of you knows a better solution that I haven't seen yet.
The same goes for when you want to deactivate the start-stop automatic; you first have to click through a few menus.
I'm really excited (and my boys are too) about the panoramic roof; my eldest would prefer to drive with the roof open all the time 😅
Also, the small adjustment options in the menu are fun features that I like, e.g., whether I want dynamic indicators or just the regular blinking function.
In this context, the Cupra app is also pretty cool.
So that's it for now; if you want to know anything else, just write in 👍🏻
@Pat89 Ich weiß zumindest, dass du den ISA einfach im Schnell-Menü deaktivieren kannst, vielleicht geht das mit der Start-Stopp Funktion auch. Von der Oberkante des Bildschirmes nach unten wischen, dann kommen die Assistenten bzw. ISA als Kurzwahl zum deaktivieren / aktivieren. Vielleicht über das + probieren Start-Stopp mit in die Leiste zu nehmen?
Ergänzung und Quelle:
Vielen Dank @DumB4zz, sehr hilfreich, habe mich auch immer gefragt was da alles einzustellen ist, ich habe noch kein Video gefunden, wo man in ruhe alles von der neuen Software zeigt.
They were included with the purchase of the vehicle.
Hi Leute,
leider wartet der erste Werkstattbesuch auf uns, das virtuelle Pedal funktioniert so gut wie garnicht, bei ca. 10 Versuchen öffnet die Heckklappe wenn ich Glück habe ein mal. Wenn ich dann den Taster zum öffnen drücke, passiert manchmal auch nichts, erst beim 5. oder 6. mal drücken öffnet sich der Kofferraum.
Da bei mir um die Ecke ein neues Autohaus meines Händlers aufgemacht hat, bin ich heute morgen dort hin um den Fehler zu demonstrieren, aber wie zu erwarten müssen sie sich das genauer anschauen.
Grüße
Drücke dir die Daumen, dass die den Fehler schnell finden, das ist ein Feature, worauf ich mich eigentlich freue, hoffentlich wird das nicht bei allen Modellen der Fall sein....
